zetec turbo compession ratio
Old Oct 2, 2005 | 02:41 PM
sammy's Avatar
sammy
Default zetec turbo compession ratio
Can anyone add to this before i bolt it together? if you have experiance building 1, pay attention to the pistons i fitted & does this seem right? (last paragraph, first post)
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=114741
thanks steve
Old Oct 3, 2005 | 10:08 PM
ivorbiggun's Avatar
ivorbiggun
Hello Mate
Check out,- www.turbofast.com.au/Tfcomp.html to calculate your C/R
Not sure what head you're using if it's an Rs T remember your head volume is about
57 cc and a typical Felpro head gasket is 1mm (0.040 thou) thick.
Hope this helps
Luv n Huggs
The DR
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
