What CC zetec can take calibra turbo pistons?
Old Sep 28, 2005 | 11:33 PM
XRT_si's Avatar
XRT_si
Default What CC zetec can take calibra turbo pistons?
Ive got a set of calibra turbo pistons (well very soon will have) with the idea of using them in to make a ZVH, but looking through some sites and talking to people just a little confused - Do they fir the 1.8 block as well as the 2.0 block? Anyone know?
Old Sep 28, 2005 | 11:50 PM
Red16's Avatar
Red16
they need to be fitted into an overbored 2ltr block, but they will drop the c/r too much when used in a ZVH engine. People generally use the vauxhall XE pistons in the ZVH engines and vauxhall LET pistons in Zetec Turbo engines.
Old Sep 29, 2005 | 11:00 PM
XRT_si's Avatar
XRT_si
IS that right?! But the LET pistons do still fit in the 1.8 Zetec engine?
Old Sep 29, 2005 | 11:01 PM
Red16's Avatar
Red16
the LET pistons are 86mm diameter so wont fit the 1.8
Old Sep 29, 2005 | 11:25 PM
XRT_si's Avatar
XRT_si
Bugger so looks like iam after a 2.0 Zetec. Guessing its the same for the XE pistons in a 1.8?
Cheers for the help by the way, its very much appreciated!
Old Sep 30, 2005 | 01:12 AM
Red16's Avatar
Red16
yeah, think both the vauxhall pistons are 86mm
Old Sep 30, 2005 | 06:12 AM
Ginge !'s Avatar
Ginge !
just finding my feet
yeah both are 86mill
Old Sep 30, 2005 | 03:13 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
As far as I know there are no "off the shelf" fit pistons suitable for any 1.8 zetec (OEM pistons that is).
For a 2ltr block (bored to 86mm - aka "2.1"), you have the choice of from Vauxhall:
Calibra Turbo (LET) Pistons, suitable for 16v Zetec turbos (CR too low for 16v!)
Astra GTE XE pistons, suitable for ZVH 8v conversions (CR too high for 16v!)
2ltr blocks arnt much these days!
Old Sep 30, 2005 | 05:02 PM
XRT_si's Avatar
XRT_si
Ok then will they fit any Zetec block e.g. silver or black top? And i understand i have to use a 1.8 Zetec inlet? In which case ill start collecting bits!
Cheers guys!
Old Sep 30, 2005 | 05:56 PM
CarlRsT's Avatar
CarlRsT
If I break my RsT I can sell you an ian howell built 2.1 and l8 cossie management with the loom and coilpack conversion, greens,3 bar,uprated box if yer interested in the new year
Old Sep 30, 2005 | 07:31 PM
XRT_si's Avatar
XRT_si
I would defo be interested...just depends how much you wanted for it
Old Sep 30, 2005 | 07:36 PM
PhilM's Avatar
PhilM
Vauxhall pistons will only work in/with Mondeo type blocks and rods.....cant stick them in a focus block (black top)!
Old Sep 30, 2005 | 07:55 PM
Ginge !'s Avatar
Ginge !
thats ok phil as the back top dont fit anyway
Old Oct 1, 2005 | 07:27 PM
PhilM's Avatar
PhilM
What makes you say that Ginge?
Old Oct 1, 2005 | 07:38 PM
Ginge !'s Avatar
Ginge !
phil it dont fit without HOOGE mods, hence why i said that, he wants a cheep conversion tooo
as he only blows em up
Old Oct 1, 2005 | 08:06 PM
PhilM's Avatar
PhilM
Hows that then? What huge mods is that?
Cheap conversion.....go Silver top 16v zetec with Calibra turbo pistons
robnock
21
May 13, 2019 05:29 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
