questions on restoring your car
Old Sep 27, 2005 | 07:18 PM
c9sse's Avatar
c9sse
Default questions on restoring your car
i am starting to restore my 3 door cosworth but before i start throwing things away that dont look to good what can you still get.
fuel lines or can you uprate them
same with brake lines and fittings
bolts
the little clips for 13mm bolts that hold the tank on
any help on this would be great or any other part that you know that i have not thought of.
i hope to take every nut and bolt off.
thanks darren
Old Sep 27, 2005 | 09:36 PM
rscostalot's Avatar
rscostalot
hi m8
just did mine,not threw choice thou..
You can get alot of the parts from www.fordpartsuk.com,you just fill in a form to say what your after and they check for you...I got aload of parts from my local ford dealer...
Be careful when you take the fuel/brake line clips of underneath as they are a bas*ard to get hold of along with the bodykit clips "wheelarches"
Have fun and goodluck...
Old Sep 28, 2005 | 10:44 AM
fomoco90's Avatar
fomoco90
if the clips you mean are the same ones used on an ERST, that can hold up to 4 lines, I have some just say so if ya brake any
Old Oct 2, 2005 | 09:35 PM
c9sse's Avatar
c9sse
can you still get all your cables from ford still.
brake,clutch,speedo and accelerator
anyone know how much avo charge to refurb rear coilovers
cheers darren
A.t.p
Aug 15, 2015 11:37 AM
Perfmr2
Aug 6, 2015 07:30 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
