Can you check if a Normally Aspirated car is running lean?
Old Sep 16, 2005 | 09:55 AM
SapphyMike's Avatar
SapphyMike
Default Can you check if a Normally Aspirated car is running lean?
if so, how?
Old Sep 16, 2005 | 09:59 AM
Stick a wideband sensor up it mate.
But lean on a N/A car isnt quite the same as on a turbo car, very common for a turbo car to be running in the 12s or even 11s but N/A tend not to drop that low even when accelerating.
Old Sep 16, 2005 | 10:00 AM
Jim Galbally's Avatar
Jim Galbally
exactly same way you do with a turbo motor
foreigneRS's Avatar
foreigneRS
Testing the future
with a lambda sensor or other exhaust gas analyser
the colour of the plugs or exhaust pipe can give you a clue, but that is a combination of mixture and ignition timing so you have to know what you're looking at. also depends on the last running condition.
Old Sep 16, 2005 | 10:01 AM
Jim Galbally
thats a point, you can plug chop a N/A car... you wouldnt dare do that on a turbo motor
Old Sep 16, 2005 | 10:06 AM
SapphyMike's Avatar
SapphyMike
my n/a car has 2 lambda sensors already (its a V6).
i guess i couldnt take any readings from these?
Old Sep 16, 2005 | 10:13 AM
You wont get anything very useful out of the narrow band sensors.
Old Sep 16, 2005 | 10:25 AM
SapphyMike's Avatar
SapphyMike
bummer..
and wideband stuff isnt cheap either
Old Sep 16, 2005 | 10:28 AM
Where are you based?
If you are in the south of england i can probably pop round and give you a hand with it using my wideband setup?
Old Sep 16, 2005 | 10:29 AM
Neil S's Avatar
Neil S
Take it to someone with a wideband then!
Neil.
Neil S's Avatar
Neil S
He lives in Hull Chip - the areshole of the North
Neil.
Old Sep 16, 2005 | 10:33 AM
Fucking typical, about as far away as its posisble to get from me then!
Old Sep 16, 2005 | 10:38 AM
Neil S's Avatar
Neil S
I'd keep it that way too Chip - he smells vaguely of cod
Neil.
Old Sep 16, 2005 | 10:42 AM
PMSL @ "vaguely of cod"
Old Sep 16, 2005 | 10:49 AM
SapphyMike's Avatar
SapphyMike
Aye chip, unfortunately i am in Hull, far too close to that geordie wannabe Neil S for comfort too
Old Sep 16, 2005 | 11:02 AM
foreigneRS's Avatar
foreigneRS
Testing the future
or use a gunson colourtune - a see through spark plug that allows you to see the combustion colour that indicates the mixture. bit tricking at speed though
Old Sep 16, 2005 | 11:15 AM
SapphyMike's Avatar
SapphyMike
depends if i can get a small person to fit under the bonnet LOL
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
ginger1979
Jul 31, 2015 09:56 PM
BMROVAL
Shows & Track Days
Jul 31, 2015 05:32 PM
