How do u make a cossie better on fuel
Hello i have been told that by changing to a different ecu and i think light blue injectors the car will use alot less fuel.
Is this true and if so what do i need to do it.
Rich
Rich
lol cheers for the replys people very helpful
, i dont mind what it costs, i was told that use a later ecu it uses less fuel off boost and as i use the car daily this would be nice
Rich
, i dont mind what it costs, i was told that use a later ecu it uses less fuel off boost and as i use the car daily this would be nice Rich
I think you are thinking of L8 ecu with closed loop control, MSD do this and I think upto green injectors DIY, I have read reports on here of how much better it is, but I would think staying on std injectors with std or stage 1 chip would be best method.
Mine absorbs the stuff, A full tank will give me just over 200 miles
I don't use the car every day, only weekends. I don't really care as i bought the car to abuse the jap crap.
mine does around 65 miles to a tenners optimax around town, which im happy with - if i wanted more id get a small engine car or diseasal
id say i would touch close to 300miles
when i was on stage 3 and greens i was getting around 200-220 miles - this would be less i drove it hard.
Now on stage 4 , 400bhp on motorsport blue injectors and I get roughyl the same mileage per tank and can get it as low as 150 miles per tank if driven hard. But i did get it remapped by ahemd bayjoo and that made sooo much difference.
May be best to get your car resetup - altho this shoudl be done at least once a year.
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
