S2, wear in bigends give low oil pressure?
Old Sep 8, 2005 | 10:05 PM
Neil Clark's Avatar
Neil Clark
Default S2, wear in bigends give low oil pressure?
My mates having a nitemare!. Will wear in the bigend shells give low oil pressure?
Cheers all!
Old Sep 8, 2005 | 10:23 PM
GrimmeRS2K's Avatar
GrimmeRS2K
id say so, also checked oil pump?, oil pump pick up pipe?
Old Sep 8, 2005 | 10:25 PM
Neil Clark's Avatar
Neil Clark
Best way to check oil pump? pickup pipe clean
Old Sep 8, 2005 | 10:29 PM
GrimmeRS2K's Avatar
GrimmeRS2K
not sure, but its cheaper to try an oil pump rather than shells etc
pressure should be 2.8bar at 2k revs, from cold will be higher, idle around 1.6bar from a standard pump
Old Sep 8, 2005 | 10:31 PM
Neil Clark's Avatar
Neil Clark
Nowhere near but not sure if its the shells doin it...
Old Sep 8, 2005 | 10:37 PM
GrimmeRS2K's Avatar
GrimmeRS2K
if its a high mileage lump, could be the shells......
but if it was me, id slap a pump on it and try just incase
Old Sep 8, 2005 | 10:46 PM
Neil Clark's Avatar
Neil Clark
Any idea how much a standard pump is?
Old Sep 8, 2005 | 10:56 PM
GrimmeRS2K's Avatar
GrimmeRS2K
60 quid approx, try burton power.
Old Sep 8, 2005 | 10:59 PM
Neil Clark's Avatar
Neil Clark
Cheers bud
Old Sep 8, 2005 | 11:24 PM
Red16's Avatar
Red16
cant see it being big ends as theyre not fed oil under pressure unlike the crank main bearings, if you had a main bearing shell badly worn or scored in the right place it could allow oil to drain straight back to sump lowering oil pressure but its ulikely.
Old Sep 9, 2005 | 12:04 AM
thebigyin's Avatar
thebigyin
pump costs about 90 quid,m8 bought one couple of days ago
Old Sep 9, 2005 | 12:23 AM
Rs Baz's Avatar
Rs Baz
dam ive just put a brand new one in the bin
you can get an uprated one for £90 mate
JK12
33
Apr 26, 2021 12:09 PM
yatta
May 21, 2016 10:31 PM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
