more bits added engine internals take a look
right i have
standard air box both bits with all clips and not broke offers
metering unit £35
powder coated 90spec rocker cover, never used but few sracthes in blue
£10 prov sold
efi inlet no charge sensor or adaptor (still available at fords) £25
comes with, fuel rail, injectors
efi cylinder head needs cam and lifters £10
mfi cylinder head complete £30
ofac ecu, map sensor, edis module £200
efi flywheel, £10
erst flywheel £10
also rst crank and rods with std pistons but no.3 melted, offers
rst inlet, injector rail, injectors throttle bodies, offers
all plus postage
pics on request
metering unit £35
£10 prov sold
efi flywheel, £10
erst flywheel £10
all plus postage
pics on request
heres some more bits
fully polished and ported efi cylinder head, 3 angle valves, new stem seals,
i had this done by a local company who do a lot of work for ferrari, suburu, jag and th epeugeot rally team
this head is a work of art
ideal for big power apllications
never fitted to car as im not going efi anymore
£350 no offers plus postage as it cost me a lot more so bargain
also
blue samco boost hoses £50 plus postage
dumpvalve not included
standard boost hoses, no splits or cuts
£20 plus postage
metering unit price above
efi inlet
also
£20 plus postage
efi inlet
as to go with the ported head i also had some other engine work done
fully lightened and balanced bottom end
this inc fly wheel, crank, rods and pistons
now this is what i have for sale
knife edge crank, fully balanced, and regrinded
mahle low comp pistons with rings and ploished,blanced,shot peened rods
these will have to go together as the pistons were heated up to the rods
efi flywheel
xr efi block but with oil returns machined out for turbo looks factory
the pistons are .5 over size
i would like to sell this lot complete as a whole item as everything is suited to each component
but will take sensible offers on above also a clutch has been balanced as well
all new and hasnt been fitted just stored in my room plus new bottom end shells these will go wth crank if right price
offers on above
efi flywheel
offers on above
do you know the spec of the valves in the head please mate???
are they sodium filled,,,,any chance of a spec sheet for it from the company as i will need them to cope with anti lag?
cheers
cheers
the head is provisionally sold mate
but the valves are std frst
so if these are sodium filled then thats what they are
spec is what i have described
but if sale doesnt go through then i will get a spec
JoeyBoyden
Jan 4, 2024 02:36 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
