fuel pump on zetec turbo
Old Aug 30, 2005 | 08:49 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default fuel pump on zetec turbo
i have just won fuel pump on ebay its a sytec grp a ecos style pump says zetec frst etc will i have to modifiy conector to go in or should it b the same,also do i have to uprate fuel lines? sorry going on mk5 xr3i 130mod...
Old Aug 31, 2005 | 05:51 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
i dont belive no1 knows com on guys
Old Aug 31, 2005 | 09:29 PM
tonyturbo's Avatar
tonyturbo
pump will fit straight in but the multi plug will be different. wiring will need some mods. dont want sparks in a petrol tank. when you change it make sure its in properly. took me 6 goes to get mine to stop falling out. most annoying. couple of cable ties cured it in the end.
Old Sep 4, 2005 | 09:01 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
cheers tony i am using rs2000 tank and cradle just got head bk on should get ecu off u rnd 28th
robnock
21
May 13, 2019 05:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
