MY DYNO FIGURES
Hi
My engine was Dynoed today at Norris Designs. I will give the figures & a few thoughts on the day, full results etc will be posted later.
Mark had promised 600bhp/500ft/lb with the probable help of race fuel.
That was not required & on Pump Fuel (Optimax) it made 613.8bhp & 507.8ft/lb this was achieved with 32psi of Boost. Higher Boost was not tried because Mark/Simon agreed we had hit the 'sweet spot' so the champagne was broken out or in this case tea.
The use of Optimax was verified by two non madette personel , who i expect will post when they read this.
The car is jetted to run 150shot of Nitrous , which Mark pointed out meant 764bhp in the car on pump fuel at all times
We then moved on to the race fuel, which made gains in Torque & horsepower & saw 600+ way past 7.5k. The gains were not spectacular however & for totb3 Mark declared 764 enough (pussy) . However a future Topspeed attempt may see us using the ' hard stuff'.
Rod
Rod
Would be interesting to see what both cars can do. Was going to suggest a grudge match feature but i think both cars deserve full features and a place on the cover.
We would of course be happy to time both cars when you are ready for a feature.
totally awesome day out, thanks to simon norris and co for putting up with our constant tea demands and minor fabrications
thx to sunny for helping us out as i left my wallet at home
mark/rod
awesome,100% spot on what was acheived today, even the evo boys were surprises
mark/rod
Very Good Rod!
Not to steal your thunder, My tuner called me today sounded very happy!!! I just made 561HP At the wheels!! it was at 8300 rpm and 26lbs of boost! without NOS aswell!! that is a very special XR he has
Originally Posted by dingy
How much way past 7.5k were you also ?
My engine does just under 8k and karls does well
It made 600 at 6.2k & was still 608 at 7.5k(race fuel)) where the graph stops ,think the limiter will be at 8k, cant give Power above 7.5 as it aint on the graph. Im down from the clouds now so remove 'way past '
Originally Posted by Danny B
Well done ALL involved, What race fuel do you use Rod, we might be able to supply you something else to try as Hauser's are the UK VP Race Fuels dealers
Mark has the fuel if we require it for a future Topspeed event.
Thanks for the offer.
Whats the latest position with your engine ?.
Originally Posted by Porkie
Awesome, well done Rod. looking forward to TOTB... hopefully we can show the Skylines a thing or two
Should now make totb as Mark will not be leaving my house till its finished.
As for spec I've took a step back for a couple of months, internally the engine has it all but it's on a T34 for now so 400hp area I guess, but I also has a big nitrous tune up of which I might post pics later
Will be good to see your car in action soon then
