CRANK
Old Nov 19, 2003 | 07:20 PM
Default CRANK
I am putting a 200 block into my 2wd cosworth, will my crank and internals bolt straight into this.
(i have new pistons)
Old Nov 20, 2003 | 10:22 PM
Toe Knee's Avatar
Toe Knee
Yea mate the block itself is the same dimention etc.
Old Nov 21, 2003 | 09:10 PM
Thanx
Old Nov 26, 2003 | 06:55 PM
Rob's Avatar
Rob
i take it the block has been honed to take the new pistons? also are they stardard cosworth items? if not i'd be looking at getting the bottom end rebalanced.
Rob
Old Nov 26, 2003 | 09:16 PM
What do you mean, The crank re balanced???
Who can do this ?????
Old Nov 27, 2003 | 06:03 PM
Rob's Avatar
Rob
well any machine shop worth their salt. rods, pistons are obviously wieghted, and balanced across all cylinders but the crank will be balanced and counterbalanced to the stock pistons and rods in some case, unless identical pistons upsetting the balance already can cause problems. however getting a fully dynamic bottom end balance is worth doing if you intending for the lump to hold together for a duration this includes getting the flywheel, clutch cover, crank, front pulley and possibly the rods and pistons. this also depends whether the crank is naturally balanced or if its counterbalance by the rods and pistons. some are some aren't. i dont know about the YB. My V6 isn't naturally balnced and is counter balanced by the rods and pistons. speak to someone with good experience with the YB and see exactly what you can get away with. 4pots when out of balance it's quite apparent unfortunately, where as my old rattly 60deg. V6 you can actually get away with a quite a bit.
However getting it balanced will make for a very smoth revving engine.
Rob
Old Nov 27, 2003 | 07:39 PM
Thanks Rob
Is there anyone in the North East area who can do this ???
Or if not can anyone recomend a company , i will travel
Old Nov 29, 2003 | 05:01 PM
I boxed up my crank, rods, pistons, flywheel and clutch and sent them to Burtons
they did a cracking job and it cost Ł100 plus the courier costs of Ł15 each way.
Old Nov 30, 2003 | 03:51 PM
Thanks mate !
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
22
Sep 24, 2015 08:14 PM
xrmalin
Sep 13, 2015 06:52 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
BRAM
Sep 8, 2015 07:11 AM
