Reconditioned adjustable RS 1600i anti roll bar For Sale
See pics, fully recon with powdercoated finish
The roll bar clamps ahve been bought and on the way to me
This is also a PERFECT upgrade for the S1 RS Turbo or any mk3 Escort, or a mk4 Escort using a MTX box or S1 box
A sensible offer won;t go un-noticed, postage will be about £20, will need to quote on postcode etc
Just to point out, the S1 already has a very similar set up to this anyway so won't really "upgrade" the S1. It would upgrade any other Mk3 or 4 though (gearbox mounting permitting on a Mk4).
they are a touch better than the S1 version. its lighter for a start plus its all one piece compared to the three bit cast iron one of the S1. the arms are ball joint types compared to the rubber bushes so another small improvement of the S1. the roll bar is hollow and thicker than the solid one on the S1. apparently hollow ones are ment to be stronger.
not massive differences but worth the investment for all those track day slags
The alloy has obvious advantages in weight. They stopped using it and went onto the S1 set up due to some legislation of crash testing IIRC...
Not sure about the ARB. I can't see a hollow tube having better torsional stress threshold over a solid bar. The tube will have a very good compression strength though.
Originally Posted by zvhturbo
PM sent
Do you have to use S1 track control arms? or can you use S2 arms?
Matt.
Matt.
Id use adjustable TCAs if you can afford it, you could have a practically perfect set up then. RSNUTs uses a very similiar set up for his rally car
Yeah, but it seems this is perfect for getting the strength and response needed WHEN it's needed eh
Someone buy this ARB set up. Much better than the standard one peice ARB set up...
Nov 3, 2015 04:08 PM
