Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
cossie powered mk2??????
Old Aug 17, 2005 | 01:35 PM
mart.rs's Avatar
mart.rs
Default cossie powered mk2??????
does anyone know how much,and how hard it is to put a cosworth lump in a mk2 escort rs2000? and whats involved?
Old Aug 17, 2005 | 02:30 PM
demolition_man's Avatar
demolition_man
hi mate, looking to do this soon also. The cosworth YB utilises the same 205 block as the injection pinto engine, therefore dependant on what engine you have in there at the moment the mounts may or may not need changing. One expense will be an atlas axle with ideally a zf motorsport diff which are expensive but apparently without it the cossie power will munch through diff after diff... to put a bog standard setup in u would be looking at, 2000 axle and diff, 1000 good engine and ancilliaries , i'm going for a t5 box which requires a bigger transmission tunnel than that of the mk2 escort. The easy option is to use the type 9 box. You should pick up a standard t5 for under 300 if you look around, however i am not sure how much power these will withstand before requiring uprated internals.
for a turbocharged YB you will need a cossie wiring loom, these tend to go for between 100-200 pounds in my experience, more with ECU.
To fit the engine the sump or crossmember needs to be adjusted as it does foul, however there are afew ways round this, one being a winged sump and there are other methods which i forget tbh :s
If the mk2 is non injection at the moment then the fuel system will need to be sorted, tank with swirl pot, pump, filter, return pipe etc which is extra expense.
Add to these costs the intercooler, radiator, and any modifications for example brakes, suspension etc and it is not the cheapest job in the world but it isnt expensive and it is awesome
hope this is some help, i have more than likely forgot a lot of things but i think i hit the key points. Good luck!
Old Aug 18, 2005 | 09:52 AM
kev16v's Avatar
kev16v
imo i would buy a whole car its cheaper in the long run.
if u nned somone to fit it for u let me no.as ive done a few
cheers kev16v
Old Aug 18, 2005 | 10:59 AM
mart.rs's Avatar
mart.rs
hey thanx guys,i dont actually have a mk2 just yet and i am thinking of buyiing a 2wd saff next year(which will be my first one at the old age of 30 ),and most of my friend have these,but i just thought about a mk2 and wondered how much it would cost to do this as i just love the mk2 rs2000 so much,its proper hard and dont know wether to just do this instead of doing what everyone else does,and of course it looks much more fun as well as power to weight!,what do you chaps think as a first rear wheel drive car!
Old Aug 22, 2005 | 02:10 PM
andyescos's Avatar
andyescos
if it's a first rwd car you'll love it. a pinto aunt to bad though with a good diff.
Old Aug 23, 2005 | 07:41 AM
mart.rs's Avatar
mart.rs
yeeeehoooooo!! wet roundabouts here we come!
Old Aug 23, 2005 | 12:29 PM
Retro Al's Avatar
Retro Al
RWD IS KING
more like on your roof in a farmers field here you come only kidding good luck with your project
Old Aug 23, 2005 | 03:34 PM
mart.rs's Avatar
mart.rs
RETRO AL do you have a cossied (white mk 2 ) by any chance????
Old Sep 11, 2005 | 03:57 PM
Punter's Avatar
Punter
From: in the workshop rebuilding my car for many years now
I WOULD NOT DO IT 2 TELL U THE TRUTH (WELL THATS ME) I LOVE THE SOUND OF A GOOD PINTO
Old Sep 11, 2005 | 11:59 PM
John Doe's Avatar
John Doe
Nope he owns this one
https://passionford.com/forum/viewto...129544&start=0
Old Oct 7, 2005 | 03:25 PM
Simmo's Avatar
Simmo
how much would you have to pay for a cossied mk2 escort anyway just out of interest?...
...I've got a stage3 saff and fancy a change!!!!
Old Oct 23, 2005 | 07:11 PM
mk2_escort_chick's Avatar
mk2_escort_chick
~*An Old Skool Laydee*~
Ahh.. the pinto engine- the reliable engine for the first time modder.
My bf has a '1980' mk 2 escort estate - he's thinking about putting a pinto in that.
Oh and the wet roundabout thing ... just make sure no1's sitting in the back ... coz it hurts them well, unless you dont like them...hehehe
Sarah XxX
Old Oct 24, 2005 | 09:16 AM
Steve Rowe's Avatar
Steve Rowe
hehehe i like that
turbotrev
14
Sep 27, 2015 10:44 AM
gcfcos
24
Sep 21, 2015 04:26 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
landaqmabba
Sep 15, 2015 07:16 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
