Stripping underside, rusty bolts help!!
Old Aug 16, 2005 | 09:18 AM
Mr C's Avatar
Mr C
Default Stripping underside, rusty bolts help!!
Ive started to undo the underside of the sapphire in preperation for a few new bits, diff and beam ARB etc only the bolts holding the anti roll bar into the floor are rotten, cant get a socket on the heads they are that bad, already snapped the outside bolts from the front seats as they are seized in the captive nut, any ideas how to remove knackered bolts and snapped seat bolts. Im running out of WD-40, spanners and patience Will I have to angle grind all of them off and drill them out or??? HELP!!
Old Aug 16, 2005 | 11:34 PM
cossiemen's Avatar
cossiemen
Whassup
get yourself a new bottle of WD-40 mate
if that doesn't work drill them out
Old Aug 17, 2005 | 08:53 AM
ste_gt's Avatar
ste_gt
Soak with wd40, wack with hammer to free off then use a decent pair of molegrips + oxy torch if required.
Old Aug 17, 2005 | 10:28 AM
Brookesy's Avatar
Brookesy
you can get a socket set that is designed to work on rounded off nuts and bolts
Old Aug 17, 2005 | 07:59 PM
Mr C's Avatar
Mr C
sorted some tonight, WD-40...again, and old 1mm smaller socket hammered onto exhisting rotten nut, hammer home till its stuck solid, undo maintaining full pressure on socket. Next question then, ahem, how do you remove said bolt from my socket
I also drilled out the seat bolts, worked a treat, managed not to strip the thread with the drill bit too which is a bonus Thanks for your suggestions all
I did see an ad for a socket like that, but not seen one recently, was it "crocodile " or something, anybody used one, any good??
Old Aug 17, 2005 | 08:09 PM
Brookesy's Avatar
Brookesy
Seen that socket called the crocodile and its crap do a search for a company called "Frost" they deal in products for people restoring cars.
Stick your socket in a vice and use an old drill bit or punch to hammer the bolt out
Old Aug 17, 2005 | 09:10 PM
ProjectBobcat's Avatar
ProjectBobcat
clamp it in a vice and then knock it out by putting a thin punch through the centre and wack it with a hammer.
Old Aug 17, 2005 | 09:46 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Its nice to see 'percussion therapy' being used to its full extent
Mc5506
Oct 5, 2015 09:57 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
