loosing coolant
Old Aug 15, 2005 | 04:58 PM
adrenalinrush's Avatar
adrenalinrush
Default loosing coolant
Hello, ive got 1.6 zetec in my fiesta and every couple of week the coolant level goes from max - min.
Now I cant see any possible leaks around the engine you know where it would crystallize, nor is the oil watery, so where is it going?
Cheers, Stevo
Old Aug 18, 2005 | 10:58 PM
Dave McB's Avatar
Dave McB
leave it running in ur drive for half an hour or so
If it leaks, check from there.
other than that, id assume it was burning it.......is the car spluttery on start up?? if yes, that could be ur prob (head gasket) check the pressure in the water system after ur half hour or so
Old Aug 19, 2005 | 06:22 PM
adrenalinrush
its not so much spluttery, but it isnt idling rite, the revs will drop rite down then go up a tiny bit again for a couple minutes continuosly then once its warmed i blip the throttle a couple times and it goes.
But zetec's have idling probs in thier lifetime dont they?
Thanks Dave
Old Aug 19, 2005 | 06:41 PM
adrenalinrush
actually I take that back, just started it up and it is spluttery
Old Aug 22, 2005 | 09:36 PM
johnnysash's Avatar
johnnysash
sounds like head gasket mate.... but it could be the water pump leaking so check that first cos no one wants to do a head gasket only to find out they still have the same problem... check it by taking off the cam cover then starting the engine and looking for any moisture/rust marks behind the cam cover (the water pump pulley is on the same belt as the alternator).
good luck either way..
Chas
Oct 5, 2015 07:13 PM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
landaqmabba
Sep 15, 2015 07:16 PM
