ERST Suspension Spinning!!!!
Old Aug 13, 2005 | 10:31 PM
BlackRs's Avatar
BlackRs
Default ERST Suspension Spinning!!!!
I am in the process of uprating my suspension on my s2 but cant seem to get the passenger side 19mm nut of the top mount as it just spins the silver part of the strut round and round what is the best way of getting round this? Have tried holding and clamping it but just wont stay still.
I am uprating to koni adjustables if that helps?
Old Aug 13, 2005 | 11:18 PM
antony215's Avatar
antony215
Escort Rs Turbo
You need to put an allen key in the top of the strut piston to stop it spining
Old Aug 14, 2005 | 09:13 AM
DazC's Avatar
DazC
Or if it's too tight for the allen key then just get a big pair of vise grips and clamp them onto the push rod as hard as you can get them on and wedge it against the inner wing. The shocker will be fucked afterwards though.
Personnaly I'd use an impact gun but not everyone has that luxury.
Old Aug 14, 2005 | 09:57 AM
BlackRs's Avatar
BlackRs
I used the allen key to get the standard shock off now i just want to tughten the koni one up. I got it started but now it just spins. Is there no other way of doing it within damaging the shock?
Old Aug 14, 2005 | 11:17 AM
DazC's Avatar
DazC
There is a small hexagon on top of the strut for a spanner. Use that. I know it's only small (8mm) but you should have a lock nut on the threads anyway stop it from coming undone.
Old Aug 14, 2005 | 11:42 AM
GrimmeRS2K's Avatar
GrimmeRS2K
i now find, its just easy to pop into a local tyre place etc, and get them to wizz them off with the airgun, and just hand tighten them down, saves damaging threads etc
dont go into a quickfit though as they wont help
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
