intercooler
Old Aug 10, 2005 | 05:34 PM
FiL_FeZ's Avatar
FiL_FeZ
Default intercooler
hey folks has anyone put a sapphire cossie intercooler onto there S1?
as i have just bought one and dont know where to mount it
cheeRS FiL_FeZ
Old Aug 10, 2005 | 10:35 PM
GrimmeRS2K's Avatar
GrimmeRS2K
quite a bit of messing about, charge carrier has to reversed, and i think the left hand inlet port on the intercooler has to be modified aswell,
they normally mount them quite high up in the grill, for all the time messing about might aswell get a pace half size, go straight in
Old Aug 11, 2005 | 08:08 AM
JesseT's Avatar
JesseT
It's a bit difficult in a s1 having a lot less space in the front to hide things as compared to a S2.
Old Aug 11, 2005 | 09:09 AM
Red16's Avatar
Red16
theres a thread on doing this in the projects section started by MJC if i remember correctly
Old Aug 11, 2005 | 04:32 PM
FiL_FeZ's Avatar
FiL_FeZ
cheers guys i had a look
Old Aug 15, 2005 | 09:33 AM
James Raby's Avatar
James Raby
That wouldn;t halp at all, no difference in performance at all, well maybe 5 degree lower ACT's, waste of money IMO
You can get it to fit easy, no need for reverse charge pipe and can run pipe work will 2 lengths of silicone pipe and a straight length of stainless piping
Correct, one sid eof the intercooler ends need adjusting by one turn for the hose to fit
Can buy kits if you find one for £100 all in, cheap and easy to do and very efficient
Old Aug 15, 2005 | 04:56 PM
FiL_FeZ's Avatar
FiL_FeZ
well i got the intercooler cheap cheap so all i need is the pipe work
James Raby's Avatar
James Raby
Lee @ Fushion will make you it, even do the intercooler end tank for ya
Old Aug 15, 2005 | 05:04 PM
FiL_FeZ's Avatar
FiL_FeZ
dont suppose u have a price or contact do u?
and what do u mean by end tank???
sorry first turboed car lol
u know a fair bit do u think it would be worth my time fitting an oil cooler?
i have the chance of one for free from a mate but ive heard that it would maybe cool down my engine oil too much for the turbo to run properly
Old Aug 15, 2005 | 05:06 PM
James Raby's Avatar
James Raby
end tank as is one end of the intercooler needs to be twisted 90 degree to suit
http://www.fusionfabrication.fsnet.co.uk/index.htm should help you
as for oil cooler cooling down too much - oh please behave! depends on what it is I suppsoe, but NEVER heard of that before
Old Aug 15, 2005 | 05:08 PM
FiL_FeZ's Avatar
FiL_FeZ
thats perfect cheers mate
much appreciated
Old Aug 15, 2005 | 05:11 PM
James Raby's Avatar
James Raby
edited address as I am a numpty
Old Aug 15, 2005 | 05:33 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
for all the effort i'd reverse the charge carrier to minimalise piping! all imo ofcourse.
Old Aug 16, 2005 | 07:20 AM
Scott R's Avatar
Scott R
James the pipework you are suggesting is fine on a S2 but will not fit on a S1, i know i tried to fit the 4x4 cooler that way. In the end i had to redesign the whole rad set-up to what you see on MJC's thread, took a little time getting everything right, but it was worth it in the long run.
So what you need to fit a 4x4 cosworth intercooler on a S1 is a smaller but wider rad mounted offset, end cans changed on 4x4 cooler with the dump valve take off filled ( no need to change one end if still using MFI), reverse charge carrier, two 8" fans, and some Samco Hoses, one of them being a reducer that you use to go from the turbo to intercooler( small end on turbo larger 53mm end to intercooler)
I am now making a different version to fit the S1, hopefully will be better than the 4x4 set-up, but its still in the very early stages as i havent even approached Wayne/Alex @pro Alloy about making me my one off intercooler, hope they can follow my cardboard design lol
I dont like the any version that is offered for the S1, nearly all the big intercoolers require cutting of the front panel to allow fitment. they also stick the fans in front the intercooler, blocking the air flow!
what i am working on at the moment is a rad intercooler setup that will use (hopefully) a 10" or 12" fan behind the rad, and a big deep intercooler at the front.
If anyone requires any info on where they can get the set-up like MJC and soon to be RSShawn let me know and i will pass on the details
Old Aug 16, 2005 | 09:05 AM
James Raby's Avatar
James Raby
Scott, you come in useful at times matey
Old Aug 16, 2005 | 09:37 AM
Scott R's Avatar
Scott R
Not often though
If you dont mind cutting about the front panel then there are some great options, at a squeeze you can get the 500 cooler in
Old Aug 20, 2005 | 06:15 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
See ya tomorrow.....
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
