Fitting the flywheel, clutch and cover plate to a cos engine
Old Aug 7, 2005 | 12:12 PM
DaveEscos's Avatar
DaveEscos
Default Fitting the flywheel, clutch and cover plate to a cos engine
Can ome kind person please run me through this?
the engine ois out so should be simple?
do i have to allign the clutch also?
anyhelp would be great
cheers
Old Aug 7, 2005 | 12:15 PM
SimonT's Avatar
SimonT
how did last night go dave?
Old Aug 7, 2005 | 12:19 PM
DaveEscos's Avatar
DaveEscos
good cheers Si. Quite a few people loving the dnb!
why didnt you reach?
Old Aug 7, 2005 | 12:22 PM
Stu @ M Developments's Avatar
PassionFords Creator
Fit flywheel to crank, rotate till all holes align (Only goes on 1 way)
Fit bolts with decent studlock to correct torque.
Fit pressure plate underneath cover (Get teh plate the right way round Shallow side to engine)
Fit the 10mm headed bolts to cover loosely... and align the pressure plate up to the spigot bearing before tightening down the cover to the correct torque in an even manner, again using decent studlock compound.
Simple 20min job.
Old Aug 7, 2005 | 12:25 PM
DaveEscos's Avatar
DaveEscos
appreciated Stu!
Old Aug 7, 2005 | 01:09 PM
Ginge !'s Avatar
Ginge !
just finding my feet
dave get the plate the riight way round, i done one the other week and got it the wring way, yes it does still fit but dont change gear, makes ya feel a right lemon
track.focus'd
Aug 12, 2015 05:53 PM
ray barker
Aug 7, 2015 09:00 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
