help needed removing fwd drive shaft question
Old Aug 6, 2005 | 03:33 PM
Rob Virgo's Avatar
Rob Virgo
Default help needed removing fwd drive shaft question
replacing cv on fwd motor,how do i remove the split washer holding it in place.its like a heavy duty circlip.
cheers
rob
Old Aug 6, 2005 | 03:39 PM
NUTS RuS's Avatar
NUTS RuS
?? What car.
Most just have a circlip holding the joint on.
Old Aug 6, 2005 | 03:49 PM
Rob Virgo's Avatar
Rob Virgo
NUTS RuS,
rover 200 coupe ,
its like a circlip but with out the hole to locate pliers.
its like a washer with a bit cut out.cant grab it,
rob
Old Aug 6, 2005 | 03:50 PM
330cossie's Avatar
330cossie
Get the gaitor out the way and hit the back of the joint with a hammer thats the only way they come off,you'll have fun trying to get it back on though.
Old Aug 6, 2005 | 03:54 PM
NUTS RuS's Avatar
NUTS RuS
See above
Rob Virgo's Avatar
Rob Virgo
330cossie,
hit the joint where , cant see it popping out that easey.
cheers
Old Aug 6, 2005 | 03:58 PM
330cossie's Avatar
330cossie
hold the shaft in one hand and hit the back of the cv joint with a hammer so that the whole joint come's off the shaft,forget about the retaining clip you can see you dont touch that
Old Aug 6, 2005 | 04:00 PM
330cossie's Avatar
330cossie
Done it?
Old Aug 6, 2005 | 05:03 PM
Rob Virgo's Avatar
Rob Virgo
330cossie,
tried hitting the cv/hub outwards but i cant hold it enough.it feels like i will pull it out of the gearbox end.i presume there is another clip holding the shaft in there.dont want to have to do that boot and joint to if i pull it out.
it seems stuck,i have got the retaining clip off the shaft at disc end now.
rob
Old Aug 6, 2005 | 05:50 PM
330cossie's Avatar
330cossie
No probs m8, but they do come off the way i explained,good luck in getting it back together.
Old Aug 6, 2005 | 05:58 PM
330cossie's Avatar
330cossie
Just a thought but you have got the cv joint out from the hub end (normally dropping the bottom ball joint to do this)
Old Aug 6, 2005 | 06:49 PM
morto's Avatar
morto
try holding the disk and giving it a good pull outwards, mine just poped out that way i no its a differant car but sounds like the same with a l;ittle clip that holds it in , haynes told me to put a screwdriver in and bang it , but thats a load of crap .. a guy off here told me what iv told you and it came out real easy, and put it back in the same way, just feel for the splines and give it a gentle push forward..works a treat mate
andy
Old Aug 6, 2005 | 06:50 PM
morto's Avatar
morto
330cossie is correct all ball joints will have to come off
and ther a coont..
andy
Old Aug 6, 2005 | 06:55 PM
Rob Virgo's Avatar
Rob Virgo
ill put pics up
cheers
Old Aug 6, 2005 | 07:11 PM
Rob Virgo's Avatar
Rob Virgo
lads ,
pics of cv joint ,cant get the cv off to get the boot in between.
this is the bit i need to remove (the clip was almost in the cv joint if you can see,i have it out now
rob
Old Aug 6, 2005 | 08:22 PM
330cossie's Avatar
330cossie
First of all Rob i dont know how you got the retaining clip out with the cv joint still in situe but seeing as you have there's nothing to stop the joint from coming off the shaft,as i said before it's just a case of persueding it with a heavy hammer,if you make sure the cv joint is straight like in the first picture when you hit it it will come off,it's obviously being stuborn like most female's but persistance will pay off
p.s if the hammer in the second picture is the one your using you will have trouble,get yourself a club hammer,you need to use something with a bit of wieght to it.
Old Aug 6, 2005 | 09:45 PM
Rob Virgo's Avatar
Rob Virgo
330cossie,
what does the retaining clip hold on then,
i have a club hammer but was afraid of damaging the cv joint or knockin the shaft out of the gearbox.
will try again am
thanks for the help lads.
rob
Old Aug 6, 2005 | 10:09 PM
330cossie's Avatar
330cossie
Rob when you do get the joint off your question will be answered,i think you'll find that the cv joint must of moved as you were able to get the clip out, but you will need to put the clip back in it's locating groove on the driveshaft before the cv joint goes back on.
Good luck m8 n let us know how you get on,
will check post when i get back from ford fair.
Old Aug 11, 2005 | 11:00 AM
Rob Virgo's Avatar
Rob Virgo
still no luck lads,have been told there may be a second clip 5 mm from the end of the drive shaft .cant get at it though
rob
RockinRein
Aug 19, 2015 07:08 PM
col93saphcos
Aug 7, 2015 03:21 PM
Bosch
Aug 4, 2015 05:14 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
