bleeding cooling system 2wd saff?
Old Jul 23, 2005 | 11:27 AM
gibbo frst's Avatar
gibbo frst
Default bleeding cooling system 2wd saff?
am i supposed to bleed the system after its been flushed as it dont seem to be working right the fans cut in but take ages to go off and im sure the rad dont get hot all over. pretty sure the water supposed to go through the turbo from bottom and out the top back into header tank but if i take the hose off seems dry inside. maybe their is something ive forgot..? any help please?
Old Jul 23, 2005 | 03:31 PM
K18NEO's Avatar
K18NEO
yeh just take the bottom hose on the rad, let it all leak out, put it back on, get 2 litres of coolant, antifreeze, and top it up with water... "note it will go down on first couple of jurneys"
Old Jul 23, 2005 | 06:07 PM
gibbo frst's Avatar
gibbo frst
basically its got a new motor in so re filled from empty seems to warm up ok as did on old engine but im sure their is no water going through the turbo. not sure how i can check this..
Old Jul 23, 2005 | 08:11 PM
Alvyn's Avatar
Alvyn
[but im sure their is no water going through the turbo. not sure how i can check this..[/quote]
the water will be running through the turbo water return pipe(one that's across the top of the rocker) and feeding back into the header if it's working correctly
Old Jul 24, 2005 | 07:32 AM
gibbo frst's Avatar
gibbo frst
yeah thats the one ive been taking off to see if any water comes through. o got rid of an air lock at the bottom of the turbo where it comes out of the thermostat housing and had water running onto it but cant seem to get it to come outof the top pipe. i had this prob before and it sort of cured itself its just i can feel their is something not right about it.. or maybe i aint got a clue..
Old Jul 24, 2005 | 08:00 AM
Alvyn's Avatar
Alvyn
just for a test take the thermstat out and see if the water will flow then(maybe it stuck) or the rad is blocked (furred up and cant allow the water to flow round)
Old Jul 24, 2005 | 08:10 AM
gibbo frst's Avatar
gibbo frst
thought of that but it has brand new rad , thermostat all pipes were off and cleaned when engine was out new engine brand new turbo.. im sure it has air in the system as ive bled it from the places like thermostat housing just normaly i can get it to come out from the top of the turbo.. which when i took it for a slow drive round the block seemed to get very hot. although temp gauge didnt read that hot.. i know the turbos can be run without water but as its their id rather use it.. if i get time ill have another go later..
Old Jul 25, 2005 | 11:42 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the water should run throgh the turbo all of the time, not just when the thermostat is open.
Old Jul 25, 2005 | 05:05 PM
rabmc's Avatar
rabmc
Easy take header tank cap off if u have alloy one , u should see water flowing into it from hose coming from turbo to header tank or have i missed something by not reading all of this
Old Jul 27, 2005 | 12:59 PM
peter.carman's Avatar
peter.carman
i wouldnt trust a new thermostat,ive had loads of dodgy ones,they break dead easy in transit
kevin36
Sep 9, 2015 11:12 AM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
ST-170
Sep 4, 2015 11:02 AM
