fookin help me
Old Jul 20, 2005 | 03:39 PM
fox3's Avatar
fox3
Default fookin help me
no spark???s1 turbo taken to garage had new dizzy plugs leads d,cap coil blokes had it two weeks what else could it be ????????????/ could it be that esc 2 thingy ?soz i dont know much about cars really read escort manual only thing i can see is that esc 2 could it be that
Old Jul 20, 2005 | 04:01 PM
1.9s1's Avatar
1.9s1
I know this probably doesn't help much but i had the same trouble with mine last year, changed everything and still no spark ended up pulling the whole lot out in the end and putting efi management in only thing i didn't try at the time though was the esc2 unit so could possably be your problem
Old Jul 20, 2005 | 05:35 PM
Stoo's Avatar
Stoo
Ontop of the Dizzy there is a cheap and weak plastic connection.Check that for breaks as it 'may' be a distributer fault..?
There is a small wire in there that is prone to letting go,im not sure if that can be replaced or youd need the whold dizzy unit though
Old Jul 20, 2005 | 06:07 PM
fox3's Avatar
fox3
had another dizzy on no luck with that .guy at garage wont have it when i tell him about that esc 2 .cant really afford to go efi
Old Jul 20, 2005 | 06:10 PM
fox3's Avatar
fox3
this esc2 ? is it easy to change ?and where is it
Old Jul 20, 2005 | 07:13 PM
L33 BYT's Avatar
L33 BYT
Any alarm or immobilsor on it. Sorry spelling!
Old Jul 20, 2005 | 11:12 PM
GrimmeRS2K's Avatar
GrimmeRS2K
ecu is on the bluck head, silver one, some on ebay, normally about 20 quid max unchipped
check the small green wires from the coil, they run down the cross member outside the loom and back up the driverside inner wing, check there are no breaks in it,
Old Jul 22, 2005 | 07:51 AM
Stu @ M Developments's Avatar
PassionFords Creator
Follow the green wire from the distributor round the front of tyhe car, its prone for chaffing and shorting to ground at the front of the car, especially if you have a front mounted intercooler.
A clue to this is the coil can get very warm with the ignition on.
apples24
Jul 7, 2004 11:07 AM
apples24
Jun 26, 2004 09:03 AM
R4N SS
14
Jun 22, 2004 11:12 AM
cfoster
59
Jun 18, 2004 06:07 AM
