CPS (CrankPositionSensor)
Old Jul 20, 2005 | 11:47 AM
rsboy82's Avatar
rsboy82
Default CPS (CrankPositionSensor)
basically what i need to know is there anyway around not using this or maching an Escort block to fit 1 because im in the middle of swoppin from FRST to ERST and it suddenly dawned on my about the CPS
Old Jul 20, 2005 | 10:18 PM
tomsxr3i's Avatar
tomsxr3i
sorry mate but there is no one that will do this cps sensor hole for you as i had the same problem i ended up buying another block sorry mate
Old Jul 21, 2005 | 12:12 AM
rsboy82's Avatar
rsboy82
cheers mate
Old Jul 21, 2005 | 02:17 PM
JesseT's Avatar
JesseT
It's a very easy job to drill the hole. Of course not averyone has a 30mm drill bit, neither did I so I drilled it to 20mm and then grinded the rest. The block is anyhow made of quite soft material.
If you really want to get around it you can use the Sierra CVH parts that have the 36-1 and sensor in the pulley side.
DixieTheKid
11
Jun 6, 2020 11:20 AM
biggiejody
Sep 19, 2015 10:25 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
marky_g
Aug 17, 2015 12:21 PM
lockie
Jul 31, 2015 10:03 PM
