help needed
Old Jul 19, 2005 | 08:09 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default help needed
hi
ive got a 1992 k reg saff cos 4x4 and the abs does seem to work, light doesnt illuminate but you can here the pump doing its self check. so the question is does anyone know any thing about this system or know of a company that will take a look, the nearest to berkshire the better.
also does any one know where the inner fuse box is located
many thanks
mark
Old Jul 19, 2005 | 08:45 PM
Alvyn's Avatar
Alvyn
has it just stopped? have you check the bulb in the dash
Old Jul 19, 2005 | 09:29 PM
MARKYMARKONE
Default abs
hi
no i have not checked the bulb yet but shouldnt the brake pedal pulsate when pushed hard like the newer cars
mark
Old Jul 23, 2005 | 04:24 PM
MARKYMARKONE
hi
i took the clocks out today to check the bulbs and found that the last owner had done away with the bulb and relay, on the relay block connector he had bridged 2 wires together why i dont know. i have now fitted a bulb and relay, light comes on does self check and goes off but when driving at about 50mph light comes on and stays on.
what is the next most common fault abs wheel sensors or abs ecu, and can you still get them
any help would be great
mark
Old Jul 23, 2005 | 05:18 PM
RSreplica's Avatar
RSreplica
Chris Astley Motorsport
i would check for dirt/dust build up on sensors and pick up rings, ensure everything is clean, connections e.t.c. then try again,let us knopw how you get on!
Old Jul 25, 2005 | 09:51 PM
MARKYMARKONE
hi
i checked ohms and ac voltage on all 4 sensors and found that n/s/f and o/s/r werent reading at all, so i went down fords and they wanted £103 eh .
then i remembered the 4x4 at the breakers went and had a look and found them in good con and giving good values so had the lot for £10.
got back fitted them and now it all works lovely , so thanks guys for the input to helping me fix it
mark
Old Jul 26, 2005 | 08:28 AM
Alvyn's Avatar
Alvyn
so i went down fords and they wanted £103 eh :eek:
some people think removing the bulb and it's all fixed only have to spend a bit of time as you HAVE and got a result on the breakers price
glad you good it sorted
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
