help needed
hi
ive got a 1992 k reg saff cos 4x4 and the abs does seem to work, light doesnt illuminate but you can here the pump doing its self check. so the question is does anyone know any thing about this system or know of a company that will take a look, the nearest to berkshire the better.
also does any one know where the inner fuse box is located
many thanks
mark
many thanks
mark
does the light light up when you turn the ignition on?
if not then look at getting the bulb changed
if everything else works then it ight just be a duff bulb
unless you've just recently bought it and the former owner, knowing it was going to be a pain in the rs to get the abs sorted took the bulb out
bulbs are easy to change, just put your had up behind the dash panel and twist it out and swap it over
hi
i took the clocks out today to check the bulbs and found that the last owner had done away with the bulb and relay, on the relay block connector he had bridged 2 wires together why i dont know. i have now fitted a bulb and relay, light comes on does self check and goes off but when driving at about 50mph light comes on and stays on.
what is the next most common fault abs wheel sensors or abs ecu, and can you still get them
any help would be great
mark
mark
sensor
unplug it form the loom and then spin the wheel (it's a bit tricky with 4wd but you just need to get all the wheels off the ground to do it)
put a meter across the conectors and the sensor with the different reading is the one that needs chaging
don't know what the readings would be though
hi
i checked ohms and ac voltage on all 4 sensors and found that n/s/f and o/s/r werent reading at all, so i went down fords and they wanted £103 eh
then i remembered the 4x4 at the breakers went and had a look and found them in good con and giving good values so had the lot for £10.
got back fitted them and now it all works lovely
, so thanks guys for the input to helping me fix it
mark
.then i remembered the 4x4 at the breakers went and had a look and found them in good con and giving good values so had the lot for £10.
mark
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
