tesco's 99ron
Old Jul 17, 2005 | 03:55 PM
james_birch's Avatar
james_birch
Default tesco's 99ron
Anyone used it?! got an ideas?!
only 89.9p a litre at my local one (about 15miles away)......
Old Jul 17, 2005 | 04:03 PM
R4N SS's Avatar
R4N SS
thats cheaper than optimax and super unleaded
Old Jul 17, 2005 | 04:14 PM
ryan_belfast's Avatar
ryan_belfast
99ron at tescos, fuck we arent getting that over here in n.ire
Old Jul 17, 2005 | 04:15 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Any news on Shell bringing their V-Power (100RON) over here yet?
Old Jul 17, 2005 | 04:20 PM
Supermarket fuel
Stick to proper sul - esso.
Old Jul 17, 2005 | 04:23 PM
GOT2BZETEC's Avatar
GOT2BZETEC
Lol fuel convos always bring up loads of comments
Old Jul 17, 2005 | 04:33 PM
sufsRS's Avatar
sufsRS
v power wots that all about never heard of it? so how much ron is optimax???
Old Jul 17, 2005 | 05:26 PM
richm's Avatar
richm
Originally Posted by dingy
Supermarket fuel
go on then steve...?
what doesn't supermarket fuel do that Esso does?
Old Jul 17, 2005 | 05:35 PM
dave cos4x4's Avatar
dave cos4x4
I work at Shell,Stanlow plant and you want to see all the lorries filling up at the same place.
Even BP lorrys fill up at Shell.
There are all types of other companys filling up from Shell.
i do believe that there are different additives added to different ones though.
Dave.
Old Jul 17, 2005 | 05:37 PM
Paul J's Avatar
Paul J
Supermarket fuel
go on then Steve...?
What i was thinking too. Also, how will increased ron/mon affect performance on a engine mapped (safely) for 95 ron?
Supermarket fuel
Additives - fuel goes off over time
So as they ship that much its probably higher ron when its at the pump but depending on additives used means if ya run ya car once a week it might not be the same...
Shell optimax has this effect too - but doesnt loose RON as fast as some fuels.
Most high ron fuels are 95 plus additives - esso SUL is 97 RON fuel.
Old Jul 17, 2005 | 06:01 PM
AJC's Avatar
AJC
optimax 98 ron
bp super 97 ron
bog std unleaded 95 ron
IIRC
Old Jul 17, 2005 | 06:05 PM
Optimax is 97.4 to 98.4 if i remember rightly....
When it leaves the pumps....bit odd having a variable ron rating on a fuel IMHO
Old Jul 17, 2005 | 06:07 PM
Christian and Beccy
#1 in Spelling Club
V-Power is 100RON and available in Europe.
We NEED that here!!
Old Jul 17, 2005 | 06:09 PM
Whats the MON of V-power ?
Old Jul 17, 2005 | 06:34 PM
ballin's Avatar
ballin
tesco 99ron is very good apparantly, has been tested and certainly makes a difference to mine.
Old Jul 17, 2005 | 07:11 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
So every tesco has high rating super dooper? dont sound right tho does it
Old Jul 17, 2005 | 07:46 PM
ballin's Avatar
ballin
only selected stores in the south Jano, piloting it down here or summat.
but no, it dont sound right really!!! normally wouldnt go near the supermarket shite but it is apparantly the best fuel otc in uk!
Old Jul 17, 2005 | 08:04 PM
Versus_Creations
Ask me a question!
Any list's of the stocist of the higher oct from Tesco
Old Jul 17, 2005 | 08:12 PM
cossie4x4's Avatar
cossie4x4
here in Holland Shell V-power is unleaded 95 ron
Old Jul 17, 2005 | 08:14 PM
richm's Avatar
richm
OK.. I don't get this anti-supermarket fuel thing that some people have got...
What part of BS 7800:2000 specification for super-unleaded fuel doesn't the supermarket fuel comply with?? Cos everywhere I go, that is what it's labelled with and if it doesn't comply, then we've got reasonable grounds to complain
Old Jul 17, 2005 | 08:57 PM
Paul J's Avatar
Paul J
Nobody know??
Old Jul 17, 2005 | 09:16 PM
richm's Avatar
richm
Nobody know??
nope - if the engine has no issues with 95, then 97 or higher will give no benefit, apart from improving the det. margin. There will only be a performance benefit if that margin is closed up by mapping more aggresively to get some gains from ignition timing and/or boost etc..
Old Jul 17, 2005 | 09:21 PM
Paul J's Avatar
Paul J
Im sure ive seen tests in pf etc claiming gains from normal 95ron maps with higher octane's. im also thought Dingy was involved in a test of additives with NF or whatever he used to supply.
Old Jul 17, 2005 | 09:27 PM
simonc's Avatar
simonc
I have switched to using the 99 ron Tesco petrol, been using it for about the last 3 months, also put in Millers octane booster on every fill up aswell, used to get a bit of pinking before in 5th when giving it stick on optimax, switched to the 99 & millers & no pinking. Thrashed the shit out of it at brands on a trackday & was fine.
Simon.
Old Jul 17, 2005 | 09:31 PM
Paul J's Avatar
Paul J
Simon: damaging det may not be heard, if you had a problem on optimax id personally get it checked out.
Old Jul 17, 2005 | 09:58 PM
richm's Avatar
richm
If the engine has borderline pinking/det issues, then there may well be some gains - det restricts power drastically, and by moving out of the det region with higher octane fuel will reduce those losses and improve power under the same conditions.
But if this is the case, then it wasn't mapped safely for 95 fuel in the first place
Old Jul 17, 2005 | 10:07 PM
Paul J's Avatar
Paul J
What about modern engine managment, is it able to advance timing to take benifit from high ron/mon rated fuel using knock sensors etc?
Old Jul 17, 2005 | 10:20 PM
Cozzie Bhoy's Avatar
Cozzie Bhoy
Same here in Ireland, its only piss water for the price of it.
Old Jul 17, 2005 | 10:24 PM
Physio's Avatar
Physio
This fuel's been tried out by a few people on the MLR in their evo's & it seems to be ok
Cant wait till they start doing it round here.
Old Jul 17, 2005 | 10:49 PM
Daveyraveygravy's Avatar
Daveyraveygravy
I've used the Tesco 99RON stuff for a month and to be honest when i went back to using Shell optimax i found it ALOT better IMHO
The 99RON sounds good but i much prefer optimax and i think it's still the daddy
Old Jul 18, 2005 | 12:39 AM
Fiecos Dan's Avatar
Fiecos Dan
simon, i told you should sort that det by turnin down your boost or a remap, (good old rollin road mappin, that det's on the road)
and you need det can's to hear it, if you could hear it by ear then thats seriously detin.
haven't tried tesco stuff,
but sainsbury's super is good, had less det with that than optimax and bp, wen testin them on my hi comp xr2tt.
but i think ding aling might have a point for one , wot fuels last the longest b4 it goes off?
Old Jul 18, 2005 | 08:02 AM
richm's Avatar
richm
LOL @ going off... valid point I suppose, but unless it goes off in a couple of hours it won't get a chance in my cossie!!
Old Jul 18, 2005 | 08:16 AM
Fuel debates, absolute nightmare, everyone always has an opinion but rarely any facts to back it up.
Would be interesting if one of the "respected tuners" on here would do a back to back test to see how it compares, set a point like for example 5000rpm@25psi on a given engine and see how much timing each fuel can take at an AFR of 12 flat, or something like that before det, so that we get a conclusive result.
Until then, its all just gossip really IMHO.
Best advice is get your car mapped on a fuel that is always available in your area easily, and then stick to that all the time.
Old Jul 18, 2005 | 08:26 AM
richm's Avatar
richm
most sensible post on the subject I've heard yet chip..
my understanding is that BS.7800 specifies the minimum content (for SUL) and characteristic in respect of RON etc.. so they should deliver the same minimum performance. To come out with "supermarket fuel is shite" is IMO at minimum misinformed..
Old Jul 18, 2005 | 08:38 AM
Yes, thats why Optimax is now only stated at 95octane officially, where as they used to try and advertise it at 98RON but it didnt meet the required tests to satisfy that (as dingy says i believe its the difference in base fuels as optimax is tarted up 95, as opposed to based on 97)
Old Jul 20, 2005 | 01:21 PM
MGTurbo's Avatar
MGTurbo
Interesting stuff..
I have been unable to find any Tesco 99 in my neck of the woods yet.
I think the key issue with these higher octane fuels is the age of it. I've had a dodgy batch of Esso SUL that caused some mega det, yet i've used BP 95 and it didnt have any det, so that must show how badly these fuels can go off!
If Optimax is stated as minimum of 95, its there a minimum RON for normal unleaded aswell?
Old Jul 20, 2005 | 01:37 PM
mart.rs's Avatar
mart.rs
ere james where abouts did you hear about 99 ron and which tesco?
Old Jul 20, 2005 | 01:42 PM
JAP CRAP's Avatar
JAP CRAP
I originally posted up about this a few months back after seeing the thread on mlr, people with skylines, evos and supras all tested the stuff, even messing about with more/less ignition, more boost etc and concluded that the tescos stuff was better than optimax iirc....
james, where is the one your talking about then? they dont do it in colchester do they?
Old Jul 20, 2005 | 02:04 PM
mart.rs's Avatar
mart.rs
if they do i want to check it out
