2.1 16v Zetec Turbo (Mega Spec!) + FRST Bits
This is on behalf of my mate Matt who doesn't have internet access, he is selling his 2.1 Zetec turbo, its mad!, he has seen the light and is stopping messing about with FWD cars, and buying a Westfield
Everything here is from a Fiesta Turbo!
PM me and I shall pass on his contact details
Zetec Turbo Engine
2100cc 16v Zetec Turbo engine, built by Ian Howell @ Fiesta Frenzy Motorsport/Area Six. The engine is still at Ian Howells and will be avalible in a couple of weeks. The engine will be supplied with the turbo and inlet/exhaust manifolds loose and a number of ancillaries required including the engine mount, oil feed pipe, custom water pipes etc. Please note this engine has never been started.
Spec-
2100cc with BRAND NEW 86mm Diameter Fiesta Frenzy Spec Aris Pistons
Eagle H-Section Forged Steel Con Rods
BRAND NEW ARP Conrod bolts
BRAND NEW oil pump (1800cc Zetec Fiesta)
Less than 30 miles old crank
BRAND NEW shells, rings, seals etc
7.6:1 compression ratio
Fiesta Frenzy Ultimate Camshafts
Fiesta Frenzy Uprated Valve Springs
Focus Central Blue Vernier Pulleys
APR Cam Sprocket Bolts
Blue 8mm Magnecor Igntion Leads
1800cc Sump
BRAND NEW Ford Motorsport Tubular Exhaust Manifold
BRAND NEW GT28RS Ball Bearing Turbocharger with 0.64 exhaust housing
Extensively Modified 1800cc Alloy Inlet Manifold and throttle body
440cc Ford Racing Injectors
FSE Motorsport Fuel pressure Regulator with gauge
OFAC Engine Loom with ECU, Motorsport Developments Live Map Chip for Zetec Turbo (Will require remap), AMAL and MAP sensors, and a Cat One Alarm (Wired Into the loom)
Should easily make 320bhp+ with this spec, the ball bearing turbo is absolutely perfect for ZT's, minimal lag, much quicker than a journal bearing turbo, good to 350bhp
If you just price up some of the parts in that list you will see i'm not asking to much
£3250 *CR*
Gearbox
Rebuilt gearbox with Quiafe ATB differential, less than 2000 miles use and only really used when running in. Rebuilt by the same person who rebuilds Ian Howells gearbox's, £600ish for the diff alone usually.
£580 *CR*
Clutch
Fiesta Frenzy Motorsport Zetec Turbo Spec Helix Paddle Clutch
Less than 600 miles use, 500 of which were running in. Clutch cover, plate and bearing supplied. Much much better than the Alcon and AP clutches.
£300 *DP*
Intercooler, Breather Tank, Fan and Raditor
GRS EVO 3 Intercooler, in very good condition <--FOR FIESTA TURBO, NOT ESCORT!
£175 *DP*
GRS Ultra 520mm wide alloy radiator in very good condition, works great with intercooler
£160 *DP*
Kenlowe 10" Slimline Fan in very good condition
£45 *DP*
GRS Custom Made 2 Port Breather Tank, breathable top section, sight glass and drain, polished alloy, 2 16mm diameter ports, fits where standard jack goes.
£60 *DP*
Coilovers, Bottom Arms, and Brakes
BRAND NEW GAZ coilovers for FRST, with additional 4 drag racing springs, full ride height and damping adjustable. Very good kit, especially with the extra springs, includes damping adjust knob and c-spanner. Less than 4 months old and never fitted. Beat the lead time.
£500 *DP*
BRAND NEW Fiesta Frenzy Motorsport Lower Arms, full rose jointed and camber adjustable, transforms the handling of the car and practically eliminates torque steer, beat the lead time
£250 *DP*
ST170 Front Brakes, Includes calipers, discs, pads and mounting bolts, will fit under most 16" wheels, fits beautifully under Mondeo Si 16" Wheels. Less than 1000 miles use.
£200 *DP*
Oil Cooler and thermo block
BRAND NEW Mocal 115mm x 16row oil cooler, one mounting foot cut off and the other rounded to allow fitment into the wheel well, never used. 1/2" BSP Fittings
£35 *DP*
BRAND NEW Mocal thermoblock, screws onto Zetec oil filter base plate and opens oil to cooler at preset temperature, never fited, still in bag. 1/2" BSP fititngs
£20 *DP*
Exhaust
Custom Made Power Flow exhaust for zetec turbos with a T3 turbo and ERST exhaust manifold. 4" straight cut tailpipe and two box's, really deep and not too loud. Sounds beautifull. From turbo to tailpipe including lambda sensor boss.
£120 *CR*
Wheels
Mondeo 16" Si Wheels. 5 spokes, similar in design to Escort Cosworth wheels, good condition but a few curbs on the front wheels. With tyres with quite a bit of tread, but budget brand.
£275 *CR*
Quickshift
Torque Developments Quickshift gear linkage
£80 *DP*
Quads
Morette Quad Headlamps with Cibe Optics, painted in diamond white, good condition, small amount of paint missing where bonnet closes, not noticable when shut. Includes all wiring.
£145 *DP*
Shelf
Auto Acoustics Stealth Shelf, light grey carpet, for a pair of 6"x9" speakers. Great condition, matches the standard interior one perfectly
£50 *CR*
Interior
Full Recaro FRST interior in great condition, includes front and rear seats, door cards, carpet if required. Small cig burn in one door card.
£160 *CR*
Rear Lights
Custom Sprayed Rear Lights, similar to RS option parts but the smoked section is clear, looks fantastic on a white car
£70 *DP*
Cosworth Upgraded Fuel Pump
Used, fits FRST tank perfectly, with small modifications
£50 *DP
Cosworth Motorsport Upgraded Fuel Pump
BRAND NEW fits FRST tank perfectly with small modifications, can run ALOT of boost with this one!
£95 *DP*
Misc
Goodridge Braided Brake Lines, full car set £20 *DP* Provisionally Sold- RS_Rawli
Opening rear windows £45 *CP*
Heated Screen £40 *CR*
Bootlid, few shallow dents and a little bit of rust around the wiper £20 *CR*
Doors, both in very good condition, CDL motors not included £20 each *CR*
Bonnet with vents, small dent from crossover pipe £30 *CR* Provisionally Sold- RS_Rawli
FRST Steering rack, quicker rack than all other models £40 *DP*
Offers on all other parts including front and rear bumpers, skirts, clocks, buttons and switches, the shell, wings, repeaters, indicators, head lining, dash board, steering wheel etc etc etc
A little key:
*CR* = Collection Required
*CP* = Collection Prefered
*DP* = Delivery Possible
As said at the top, PM me and I shall pass on his contact details to you
Zetec Turbo Engine
Spec-
1800cc Sump
£3250 *CR*
Gearbox
£580 *CR*
Clutch
£300 *DP*
£175 *DP*
£160 *DP*
£45 *DP*
£60 *DP*
£500 *DP*
£250 *DP*
£200 *DP*
£35 *DP*
£20 *DP*
Exhaust
£120 *CR*
Wheels
£275 *CR*
Quickshift
£80 *DP*
Quads
£145 *DP*
Shelf
£50 *CR*
Interior
£160 *CR*
Rear Lights
£70 *DP*
£50 *DP
£95 *DP*
Misc
A little key:
wel thats kind of shot me down now hasnt it!!! lol.
if the grs cooler is for a fez, im guessin the rad is aswel??
i sent an email anyways m8, so cheers 4 the info there
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
