FAO All that have done stud conversions......
Did you have trouble drilling out the holes ?
The first hole i did.... piece of piss... no problems... went straight through.... perfect.... but i can't seem to drill the rest !!!
I thought it might be a blunt drill bit, so changed it and still can't do it !
How did you do yours ?
there was a long post about this but cant search for it, i think the general consencus was lots of that oil and some of them drill bits with ultra hard edges (pmsl how vague i dunno the name)....not diamond tipped, but the other type
I did mine with a standard HSS metal drill bit, i had 12.7mm and 12.9mm, so ran the 12.7 thru first (i actually went fairly fast and it went thru no probs all 16 holes, then ran the 12.9 thru them all.
I did let the drill bit cool between holes (ie I did 1 hole at a time, 12.7, then swapped to 12.9 to give the .7 a cool down for a few seconds).
Good luck
Good luck
Adam i bought 10 bits that Nuts RuS found for me on-line, you'll find after the first one the bit will tend to get blunter.
I think i have 3 or 4 left, not bad really and they were only 80p ish each
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Get some proper solid carbide drill bits - they`ll go through more or less anything without any problems, only disadvantages with them are they do not like thermal shock - i.e constant heating and cooling, either keep them cool or keep them hot (obviously not too hot as to soften the drill bit) they are also far more brittle than HSS, if you put too much lateral pressure on them they will shatter unlike HSS which has a lot more "bend" in it before it will snap.
