FAO Daz or Mick C.
Old Jul 15, 2005 | 06:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default FAO Daz or Mick C.
I dont have your number handy, but i guess these pics will tell you all you need to know.
The part we were missing has arrived and is fitted.
See you Tomorrow i expect?
Old Jul 15, 2005 | 06:05 PM
the strut brace's Avatar
the strut brace
ker ching!!! thats a bit of kit aint it
Old Jul 15, 2005 | 08:12 PM
DazC's Avatar
DazC
The unfortunate thing is, we can't transport it at the moment mate.
Old Jul 15, 2005 | 11:22 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
nice wrc cam sensor in the eeciv m8 if i had my old nail on the rd id move it for u
Old Jul 15, 2005 | 11:29 PM
Ginge !'s Avatar
Ginge !
just finding my feet
that engine looks familier stu
never new it was for daz's old man , bit of a engine there then
Old Jul 16, 2005 | 07:30 AM
Wounder...
Not to worry pal, im in no hurry to have her out of here, just wanted you to know it was ready after that bloody delay with the "40mm" spacer Sorry about that
Perhaps see you for a brew if nothing else.
Old Jul 16, 2005 | 09:06 AM
DazC's Avatar
DazC
Hopefully going to see if I can borrow a van from vork as I am now 100% workshop bound until my new van is delivered!
If I can we will be there this afternoon.
Old Jul 16, 2005 | 09:08 AM
Billabong's Avatar
Billabong
What's the spacer worth in terms of power / drivability? If you don't mind me asking of course?
Old Jul 16, 2005 | 09:22 AM
Im not certain myself of the ultimate limit of the spacer, but it definately improves flow after 420 bhp IMO as ive fitted one to a car running Siemens 550s and a T4 with around 440bhp and it leaned it off from 11.5:1 to 12.1:1 so was a worthwhile upgrade at this airflow level.
That said, it did richen almost all the low load sites up until around 9 psi, presumably due to the vac drop so will have had a negative effect on driveability although the driver said he couldnt tell any difference other than it was faster, whish is good feedback.
Hope this helps somewhat Bill.
Old Jul 16, 2005 | 09:41 AM
Billabong's Avatar
Billabong
Cheers Stu, you know me, just a nosey bast.... I mean have a healthy thirst for knowledge
Old Jul 16, 2005 | 09:43 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Very nice stu
Old Jul 16, 2005 | 12:28 PM
A man after my own heart Bill
Old Jul 16, 2005 | 12:50 PM
dumped's Avatar
dumped
I see you have samco hose running to the sump - I have samco hose on my breather but I seem to recall ages ago someone saying its not suitable for carrying oil and may perish early causing problems? Not on the scare just wondering
Martin
Old Jul 16, 2005 | 01:09 PM
Martin
Nope, your absolutely right its not at all ideal, and needs to be a special oil resistant lined type. That stub was there to stop the flushing oil pouring out of the breather return when i filled it to get some oil pressure and fill the followers etc. The owner will use his own pipe when he installs the engine. There are a few clips to be changed as well before the owner collects her.
Well spotted and noted though
Old Jul 16, 2005 | 01:30 PM
dumped's Avatar
dumped
yeah I'm going to stick proper hose on when i get the chance - I thought i had heard it - its looks nice but was sure it broke down
cool cool
Old Jul 16, 2005 | 01:46 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
That was actually my fault ... not Stu's - Sorry! You wouldn't believe the amount of aggro that particular spacer was, think it was jinxed from the outset (proper tears!) I did think it was abit odd when I heard 40mm thick
Still, glad to see it fits nicely
Old Jul 16, 2005 | 02:05 PM
RichardPON's Avatar
RichardPON
Samco do actually make oil resistant breather hose, but you don't even want to KNOW how pricey it is - and knowing Samco, the turnaround time will be approximately 14 months
Old Jul 16, 2005 | 02:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Bloodyhell, so all the "elbow is more restrictive than the closeness of the trumpets to the plenumn wall business wasnt correct then?
I remember when i first saw how close they were i was shocked
Old Jul 16, 2005 | 02:52 PM
I must admit i dont know teh definitive answer to that one Steve.. if you look at that elbow more closely you will see its nothing like a standard one
Old Jul 16, 2005 | 03:06 PM
slowpoke's Avatar
slowpoke
off topic i know but can you read your PM'S please stu
matt
Old Jul 16, 2005 | 10:38 PM
Sorry Matt, at least 30 to get through yet and no time to do so at moment, if its important, please call me.
Old Jul 17, 2005 | 10:55 AM
DazC's Avatar
DazC
As said, the plenum elbow is nothing like standard. There is a few more plenums which have been done like this since but this one has a spacer as well.
Old Jul 17, 2005 | 11:30 AM
Fiecos Dan's Avatar
Fiecos Dan
nice
two things,
would that spacer blow the fuel away, on a rs500 plenium.
why is the ecu temp sensor at front of head? is that where small turbo escorts are?
Old Jul 17, 2005 | 11:44 AM
DazC's Avatar
DazC
It's on a small turbo Escort head. The temp sender unit for the guage is next to No 1 spark plug, the water pipe usually at the rear of the head is between No 1 and 2 inlet runners and the temp sensor for the ECU is right at the front of the head. Also the rocker cover is different so couldn't use the old rocker cover or the Spec-R bracket and RS500 damper.
Old Jul 17, 2005 | 11:54 AM
Fiecos Dan's Avatar
Fiecos Dan
is thier a advantage of the later esc cos head?
i see daz, your old man's not usin his old md240r?
Old Jul 17, 2005 | 11:57 AM
DazC's Avatar
DazC
No mate, he has gone for a GT30 this time. The MD is sat on the bench in the garage with a rag over it to stop crap falling into it.
Old Jul 17, 2005 | 12:02 PM
THEYGOTMETOO
CUNT!
No, Plenum spacers are fine of RS500 plenums, I know of at least two cars which use that design of spacer + Rod Tarry's Sapphire also uses a plenum spacer on a RS500 plenum - just not of the same type.
61
Mar 24, 2005 09:11 AM
Azrael
Feb 17, 2005 09:26 AM
