NEED ADVICE! T3 problem,HELP!
Old Jul 14, 2005 | 05:14 PM
plynchy's Avatar
plynchy
Default NEED ADVICE! T3 problem,HELP!
Have been changing the oil post CC,and having a general fettle. I've noticed that there is some movement between the compressor/bearing housing(the alloy bit) and the exhaust housing(the cast bit).
There is a flange with some 13mm head bolts that mates these together,i've tried nipping them up but makes very little difference. Am i right in thinking that there should be ZERO movement between these 2 parts? Any help/advice most welcome!
Old Jul 14, 2005 | 05:40 PM
Alvyn's Avatar
Alvyn
they should be tight and have no movement!
think you will have to remove the turbo to do them up properly
Old Jul 14, 2005 | 06:05 PM
plynchy's Avatar
plynchy
Got the blower off,a lot of movement between the 2 parts,but very little movement on the bolts to tighten them. Have split the 2 and everything looks to be OK. This may explain why i was only running .7-.8 bar boost instead of the usual 1 bar all weekend,and it did seem to get worse. I thought the actuator was fooked but maybe not. Will have a trip over to the turbo shop in Hartlepool tomorrow.
Old Jul 14, 2005 | 06:10 PM
righthooker's Avatar
righthooker
didnt know there was one mate ?? they sell new and recon stuff??
Old Jul 14, 2005 | 06:38 PM
plynchy's Avatar
plynchy
Opened my gob too soon about it running sweet didn't i??
It's been there for years Clive,just off Brenda Road,called Turboactive,sorted out my sticky wastegate last year for £30.
Does exchange stuff etc.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
RSBryden
Sep 6, 2015 08:39 PM
