Does anyone know anything about pond fish??
We have a pond in the back garden, got about 15 gold fish in it, but we noticed last week one of them gold fish that WAS bright gold, is now a grey colour.....can't see any fungus on it, and it doesn't look ill, but still it's a bit worrying.....can anyone shed any light?
Most freshwater fish will vary in colour, which is caused by several things like water condition (PH level, oxygen/bacteria levels), or environment if captive (too many fish in too small an ecosystem) which can lead to diseases like whitespot etc.
Keep an eye on the others and if need be put the fish into a nursery tank and see how it gets on.
HTH.
HTH.
Dragon - yit doesn't look like white spot or anything, and it doesn't even look ill, just a bit strange, checked the water and its fine........but none of the others have done this we've had them 3 years or so if not longer
pmsl I don't even know tonyturbo
Originally Posted by M7 COS
Aw well.....thanks you guys
I'll have a look after work, gotta go back to slaving away now!!! Thanks mate appreciate your help
No problem!
Hope they're okay, I think they'll be fine personally.
Where's www.passiongoldfish.com when you need it!!!
So do I!!
Although they've survied without a lot of water before now pmsl....some fooker took the pipe off the pump, so it emptied the whole pond near enough, but they survived pmsl.......
Thanks again
Thanks again
You need to get out more
He's the no-body in the resto room with the 35 page thread
FPMSL
Kim - It's Tony Turbo thank you, not tonyturbo... accept no substitutes
Oh, and fish.... I know fack all, but seems like you have enough help already lol, thanks Paul
Originally Posted by kevandalice
"does anyone know about Pond Fish?"
well it was caught from Combwich ponds... 22lb mirror carp
M7 COS - Thanks for the links - perfect hun
Found a sort of explanation
My fish are changing colour
A fairly common situation arises when fish literally change colour, either all over or just parts of the body. The most common situation is when previously coloured fish turn white. Fish skin colouring is a complex subject. Fish skin contains different types of pigment cells or chromatophores, which are under the control of the hormonal and nervous systems.
Fish which are diseased often change colour, but this is usually a fading/darkening/dulling of the skin rather than an actual colour change. There are a few conditions in which there is a colour change but these are rare.
The most common causes are either nutritional deficiencies, so one could try a change of diet, water chemistry such as pH or hardness, or simply genetics.
In virtually all cases the fish appear perfectly healthy apart from the colour change and eat and swim normally. So apart from perhaps changing the diet and checking water parameters there is nothing that can be done to reverse the colour change.
As a thought, it might be a little upsetting if your goldfish becomes a whitefish, but pity the koi owner who has paid several hundred pounds (or dollars) because of the fish's perfect colours / pattern, simply to watch the colour and patterns disappear!!!!
Hi
My mums fish which is a tank with others, was bright orange, is now silver, we asked an expert and they said its because the tank is not in sunlight, they need sunlight to a degree to keep their colour, (lack of sun light), well it was in her conservatory and now in the dining room where theres no direct sun light, only the tank light, so maybe it could be to do with that.
As long as the fish is well theres nothing you can do and apparently they dont turn back either, so will prob saty that new colour.
Lisa
Lisa
keithG666
32
Jul 28, 2004 10:58 AM
