Converting 3dr to 4x4?
Old Jun 22, 2004 | 09:57 PM
Uncle Henry's Avatar
Uncle Henry
Default Converting 3dr to 4x4?
whats needed and how much work is involved?
are there any bodywork issues with clearance for the box etc?
any more info at all?
ta.
Old Jun 22, 2004 | 10:15 PM
Nick500's Avatar
Nick500
The main things you have to do for converting to 4 x 4, the front chasis legs need half moons cut into them to allow the clearance of the driveshafts. Also the tunnel needs replaced or modified to allow for the drop gear casing or transfer box! the rest more or less bolts on the diff ratios allow you to run the 7.5" rear diff along with the 4x4 front diff. but you will need the gearbox, front diff, front engine craddle, front drive shafts, both hubs then your front suspension needs changed there is a fair bit of work mate, my project car is just about finished and has been off the road now for 10 months but should be good when finished!
Nick
Go for it.
Old Jun 22, 2004 | 10:23 PM
SPADGE's Avatar
SPADGE
I don't recall seing anything cut out of my front chasis rails but will look tommorow and confirm!
Old Jun 22, 2004 | 10:26 PM
Billabong's Avatar
Billabong
Spadgeroo, IIRC the cut outs were already 'stamped' into the shells/chassis' (they probably thought about a 4wd 3dr from the off), so it's probably such a tidy job that you just don't notice it.
Old Jun 22, 2004 | 10:27 PM
Nick500's Avatar
Nick500
I don't recall seing anything cut out of my front chasis rails but will look tommorow and confirm![/quote]
I have cut them out to mirror the 4x4 chassis legs, as without them the clearance would be minimal.I would imagine they are cut a bit! you must have a different tunnel as well eh spadge?
Old Jun 22, 2004 | 10:28 PM
CozzyBrom's Avatar
CozzyBrom
am doing one at the min as we speek
looking around £350 to do all the welding and paintin and stuff
thats with the modded gear box mount aswell
Old Jun 22, 2004 | 10:29 PM
Less.'s Avatar
Less.
having a mid life crisis
Brom is there anything you cant doo
Old Jun 22, 2004 | 10:30 PM
SPADGE's Avatar
SPADGE
[/quote]
The tunnel has been modified a little on the left of the drivers footwell.
A hole was made and then a new piece, with a curve to it, welded in to allow clearance for the transfer box!
Fastmaul's Avatar
Fastmaul
K155MYRS
I should hopefully be making my XRTI 4x4 After my other Project is done.
Old Jun 22, 2004 | 10:33 PM
Nick500's Avatar
Nick500
Ok I had a whole tunnel from the 4 x 4 welded in so as I could use the standard gearbox mount. same idea! Just out of curiosity have you beefed up anything apart from the gearbox to cope with the power you run?
Nick
Old Jun 22, 2004 | 10:35 PM
All4it's Avatar
All4it
why ? it will just make the car slower .
Old Jun 22, 2004 | 10:36 PM
SPADGE's Avatar
SPADGE
Nick
Front diff is a ZF plated item using a Quaife thick casing
Rear diff is a standard 7.5 incher and will remain until i start to break them
Front driveshafts were replaced with brand new standard ones just to be on the safe side
Thats about it for now
Old Jun 22, 2004 | 10:37 PM
Uncle Henry
Cheers for the response guys
Doesnt sound like too much work actually - I had visions of the whole transmission tunnel needing modifying etc. I assume most of the bits are available from breakers at reasonable enough prices?
what are the limitations of the 4x4 transmission up to 400bhp? Is it daft money for a decent gearbox?
Old Jun 22, 2004 | 10:43 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
This is my everyday car, and in winter time here, I would be happy to have it 4x4!! and it'll be a cossie too!
Old Jun 22, 2004 | 10:46 PM
Nick500's Avatar
Nick500
Sorry mate but 4 x 4 cossies are not that great in winter either!
Azrael's Avatar
Azrael
??????????? Why?
Old Jun 22, 2004 | 10:49 PM
Nick500's Avatar
Nick500
well up here in sunny scotland it snows alot in winter!!!! even my old subaru struggled in the snow!!
On saying that I know south of the border snow is rare! and when it arrives people scratch their heads and wonder what it is!
Old Jun 22, 2004 | 10:51 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
I'm sure it beats our open diff that our XR's have..not even lsd, it's like one wheel drive!
Old Jun 22, 2004 | 10:53 PM
Azrael's Avatar
Azrael
You want to tell me about snow? HAHHAHAHAHAHAH There isn't much snow in the UK anyway compered to what we have here, so I still don't know what is bad about 4x4 Cossies in snow. I did a few kilometers this winter and it was great fun and very easy.
Old Jun 22, 2004 | 10:54 PM
Nick500's Avatar
Nick500
Thats true, would be better than that!
Old Jun 22, 2004 | 10:56 PM
Azrael's Avatar
Azrael
The best thing in snow is a good driver In fact always good driver is the most important thing, than it can be 2WD, 4WD, 50HP or 500HP. Anyway Escos is fun to drive in snow (with proper winter wheels), I don't think Sierra will be much worse.
Old Jun 22, 2004 | 11:13 PM
Godspeed's Avatar
Godspeed
XR4i to 4x4 conversion thread.
(Good pictures of tunnel conversion and bracket location)
http://forums.interford.co.uk/showth...threadid=35703
G
Old Jun 23, 2004 | 09:22 AM
RS500/364's Avatar
RS500/364
a europian 3 door they made was 4x4 so thats is more than likely the reson the stamps are there
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
mondeomark
Sep 28, 2015 06:28 AM
