WHAT PROGRAM TO COPY A COPYWRITED CD
Old Jun 22, 2004 | 10:45 AM
Gra's Avatar
Gra
Default WHAT PROGRAM TO COPY A COPYWRITED CD
As title, need to make a "backup" of Battlefield 1942, but the fookers copywrited so Clone CD or Nero wont burn it, is there a burner that can burn copywrited cd's?
Old Jun 22, 2004 | 10:47 AM
Jamz's Avatar
Jamz
Try Alcohol 120%
Old Jun 22, 2004 | 10:51 AM
Gra's Avatar
Gra
Old Jun 22, 2004 | 10:54 AM
Jamz's Avatar
Jamz
I'm not kidding, http://www.alcohol-software.com/
Old Jun 22, 2004 | 10:56 AM
Godspeed's Avatar
Godspeed
Alcohol 120% will do it, clone cd should of as well. If I remember rightly it uses safedisk2 protection.
Take note that even after you've burnt the backup it may not work because some cd-rom drives are fussy and have trouble with protected stuff.
I had that very problem, it would read the backup using the cd drive in my sons but not in mine.
Best thing to do is install alcohol, store the disc as an image then use alcohol to create a virtual drive and mount the image on the virtual drive. It will always think it has the battlefield 1942 cd in a drive and will load it in no problem.
HTH
G
Old Jun 22, 2004 | 11:25 AM
CabrioTurbo's Avatar
CabrioTurbo
Yep best idea! you can use alcohol or i use daemon tools to do it
Old Jun 22, 2004 | 11:34 AM
DaveEscos's Avatar
DaveEscos
go to
www.imagypoandwontbuythepropersoftware.com
Old Jun 22, 2004 | 11:38 AM
Gra's Avatar
Gra
fook off
Old Jun 22, 2004 | 12:00 PM
Matt's Avatar
Matt
smartripper
never failed me yet
Old Jun 22, 2004 | 12:08 PM
Jim Galbally's Avatar
Jim Galbally
depends on your CDR drive to be honest, some physically cant burn a copy protected disk... some can...
i know mine cant...
look on the cloneCD website or www.gamecopyworld.com to find out if your CDR is able to burn safedisk2 stuff...
oh and cloneCD + CloneXXL should be able to do it no problem, so if it dont work your drive's probably naff...
Iain Mac
Sep 13, 2015 09:16 PM
cozzy jeff
Sep 12, 2015 04:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
