Focus speedo cuts out, then car cuts out.
Hi. I have a problem with my 99 T reg Focus 1.8 Zetec. I'll be driving along, then the speedo cuts out. The car then become sluggish. The next time I slow down and put the clutch in, it stalls!! Ford haven't got a clue! So please please help.
Martyn
Martyn
I also have a 99 T 1.8 Focus Zetec that is playing up exactly as described. What started out as an annoying niggle has now turned to a potentially dangerous fault.
How big a job is it to change the speed sensor???
I havn't got a Haynes manual as yet so detailed information would be appreciated.
Keith
Keith
Originally Posted by cpcossie
Can be a nightmare the sensor is held in by a roll pin which normally seizes in the casing give it a good soakin with some wd40 b4 you try to take it out
I still havn't got hold of a Haynes book yet so could anyone provide a detailed description as to whereabouts it should fit.
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Escortdriver1
Jul 31, 2015 02:36 PM
