ZVH HEAD GASKETS
What gaskets (make and part numbers) are people using on their 2 litre conversions?
I am trying to get hold of at the minute a gasket for the 1.9/2.0 CVH that was made in america. Part No 9303PT2 or 9309PT.
Anyone know where I can get one from?
Dave
Dave
I've used the Zetec 2.0 multi-layer Ford gasket. To fit it the head needs a bit of welding, and then skimming flat. Its about 30 quid from Ford.
Duratec V6 head bolts - but use the CVH washers along with them.
As far as i'm aware the felpro 9303pt2 head gasket is what is rerferd to as being a group a rs turbo head gasket and are available from
www.burtonpower.com
to the sum of about 50 quid.
www.burtonpower.com
Do you guys know anything about the CVH Kevlar gaskets? We had a tuner over here grab one from Italy and we can't find the contact info or whatnot now. I am in the process of building up my 2.0l cvh (yes they were expanded from the 1.9l's over in these parts, from the factory, in 97, discontinued in 02; still ran in the focus sedans; lean-burn cc tho) and I believe I might as well grab a gasket that will hold in there for a good while. My local engine builder actually does a lot of cylinder head work for turboford.org members (mainly 2.3L) and we have been brainstorming the best setup, the kevlar gasket being more my idea. I would like to be up there, hopefully in the 2bar range within the half year. Right now working on finding the closest matching conrod to adapt over.
Thank-you for any help or dirrection.
I was also curious if the CVH bellhousing boltpattern differs with the zetec block bellhousing boltpattern, for ideas concerning a form of a ZVH setup.
Thanks!
brad
Thanks!
brad
Mc5506
Oct 5, 2015 09:57 PM
