My cars having a funny turn!!!
Hi All,
Can anyone please help, went to start my car and though she started with no problems, all the fans came on blowing really hard even though the switches are in the off position, looked in the fuse box and fuse no 34 has blown so we've replaced it but it just keeps blowing straightaway, has anyone else come across this?? if so please please please will you tell me what you did to fix it??
thanks in advance for any advice
Debbie
Debbie
if ur car is a scort or orion mkV onwards it is the fuse box itself take it out pull all fuses and relays out including bridging bars remember where they go!!! pull the box apart. front bit comes off first
inside are pins with solder on them one or two maybe more will look darker than the rest may look as if loose or burnt solder them should cure problem
inside are pins with solder on them one or two maybe more will look darker than the rest may look as if loose or burnt solder them should cure problem Thread
The Underdog
29
Sep 7, 2015 09:49 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
