Turbo problems !!!!!
Old Jun 25, 2005 | 10:36 PM
RSTEVE's Avatar
RSTEVE
Default Turbo problems !!!!!
finally got my car back last night after waiting for 6mths to have the engine rebuilt.
now got a turbo problem used to hold fine at approz 14-16 psi through the gears but now it shooting way above 20 +
it got a manual adj boost, but this is turned to the lowest setting.
the bloke who done the engine work also changed the ecu to one with a collins chip
turbo also seems to kick in at a lot lower revs any one got any ideas ?
Old Jun 25, 2005 | 10:55 PM
davidreader5's Avatar
davidreader5
HI,
With the manual boost adj, have you still got the amal valve in place,
if so check your pipe's from the turbo to the valve are correctly fitted.
also starting from scratch, the pipe that comes from the compressor of the turbo,
put it straight to the actuator, and see what the boost pressure is, it should show
the actuator pressure, if so , you have a problem with either your manual adj, or amal valve.
DAVE R.
Old Jun 25, 2005 | 11:27 PM
RSTEVE's Avatar
RSTEVE
[quote="davidreader5"]HI,
have heard a few things about this amal valve but not sure what it is is there one a s1 engine. any one got a picture ?
will try what you suggested ie take the adj boost off tmro !
thanks dave !!
will let you know
Old Jun 26, 2005 | 07:29 AM
wimble's Avatar
wimble
the amel valve is on a bracket bolted on the top of gearbox it is brown with a white top there r three pipes runing from it one to the turbo (compresor) one to the actuator and one returns to atmosphere through the meatring unit(the solid blak pipe that runs from the rocker cover)
Old Jun 27, 2005 | 11:08 PM
RSTEVE's Avatar
RSTEVE
still can't find the amal valve would it have been changed for a bleed valve ? (or am i just been stupid )
taken the adj boost valve (looks like a bleed valve) off so just got a pipe running from turbo to actuator now, not had chance to try this yet.
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
