what did i do wrong ?
Old Jun 24, 2005 | 11:04 PM
Combi_Chris's Avatar
Combi_Chris
Default what did i do wrong ?
i just got a quote from ford parts , i asked for a new brake servo and master cylinder , i was quoted 83 quid for the servo and another 93 for the master cylinder, am i going mad or are they REALLY that much , i thought they was a LOT less , or should i just go ahead and get the master cylinder, as i think thats whats busted on mine ?
anyone ???
Old Jun 24, 2005 | 11:49 PM
DazC's Avatar
DazC
I paid Ł100 for a servo 3 years ago and Ł38 for a master cylinder at the same time....
Servos are common for leaking and drawing in air, which in turn effects the running of the car....
Old Jun 24, 2005 | 11:58 PM
Combi_Chris
ok thanks guy , always god to get a fast answer
Old Jun 25, 2005 | 01:55 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Are the servo's servicable?
Old Jun 25, 2005 | 08:38 AM
adamS2RST's Avatar
adamS2RST
Daz, any way of knowing if the servo or the master cylinder / resi is the problem for drawing of air?
I think either my servo or master cylinder may have a slight air leak as you mention as when we bled the brakes up a while back you could here "air" when the pedal was being depressed..... not sure if this is normal or not though....but maybe it would explain my slight pedal travel....
Old Jun 25, 2005 | 10:10 AM
DazC's Avatar
DazC
Does the car run rough?
Get a large can of WD40 or carb cleaner and spray it round all the joints on the servo with the engine running. If the tone in the engine picks up and it runs better then the joint you're spraying is leaking. Also works on any part of the induction system.
Master cylinders do not cause air leaks. If there is an air leak round the master cylinder then it's servo related. Pedal travel is a hydraulic problem within the brake circuits.
Old Jun 25, 2005 | 01:43 PM
adamS2RST's Avatar
adamS2RST
No, well on the odd occasion it will run a bit lumpy on start up, however I dont think that would be the problem.
Thanks mate, will have to try that
When you say brake circuits, what you mean exactly? Do you mean abs related? I had the abs removed the other week too.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
DavidK
Sep 27, 2015 02:55 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
