any bike mechanics / know it alls out there? gsxr600
Old Jun 24, 2005 | 05:17 PM
apples24's Avatar
apples24
Default any bike mechanics / know it alls out there? gsxr600
gsxr600 99 v reg needs new clutch as slipping, also the exhast manifold gaskets are leaking i believe there ceramic?
how hard to do a clutch how much i looking at to have one fitted?
seen this place that sells a clutch for 37 quid but think its just the plate??
http://www.gear4bikes.com/acatalog/S...tch_Kits1.html
im fine with cars but bikes im in the dark
Old Jun 24, 2005 | 05:20 PM
The DIVA's Avatar
The DIVA
If your a competent mechanic mate the clutch should be a doddle,all you have to change usually is the fibre plates,only change the steels if they are blued to fook....
I`ll pm you my number mate .........give me a bell and ill talk you through it ....
Old Jun 24, 2005 | 05:22 PM
safflad's Avatar
safflad
get yourself a work shop manual easier than you might think especially if your competant with cars
Old Jun 24, 2005 | 05:24 PM
Chris Honeywell's Avatar
Chris Honeywell
Yeah m8 u can do it like said above just change the fibre plates
apples24's Avatar
apples24
oh so there not that bad then? spose a manual would be a good idea
nightdavva havent got the clutch yet havent even stripped the bike but suszuki quoted me 400+ to suplpy fit clutch and man gaskets lol
Old Jun 24, 2005 | 05:26 PM
gurnE's Avatar
gurnE
30 minute job
Old Jun 24, 2005 | 05:28 PM
apples24's Avatar
apples24
think ill get a manual then aye
Old Jun 24, 2005 | 05:30 PM
Graceland's Avatar
Graceland
Team HOTHOT!
nipples - you have pm
Old Jun 24, 2005 | 05:40 PM
apples24's Avatar
apples24
cool just ordered a workshop manual a clutch and a set front brake pads came to 90 quid inc deliver not bad spose
Old Jun 24, 2005 | 05:44 PM
Graceland's Avatar
Graceland
Team HOTHOT!
wounder
Old Jun 24, 2005 | 05:50 PM
The DIVA's Avatar
The DIVA
Originally Posted by gurnE
30 minute job
My record is 9 minutes from coming in the garage to back out on track...
Old Jun 24, 2005 | 05:53 PM
apples24's Avatar
apples24
fook lol it taskes me that long to have a crap
Old Jun 24, 2005 | 05:56 PM
gurnE's Avatar
gurnE
Obviously you work alot fookin quicker when everything is red hot
Old Jun 24, 2005 | 05:57 PM
apples24's Avatar
apples24
so wots the process for clutch change?
The DIVA's Avatar
The DIVA
yep.............you end up with skin like elephant hide when your endurance racing...
Old Jun 24, 2005 | 06:01 PM
gurnE's Avatar
gurnE
Soak new plates in engine oil.
Fairing off, clutch cover off, undo the 6 or so bolts in the middle of the clutch basket.
Remove the cover, pull out the alternate fibre and metal plates.
As said, only replace the metal plates if they are badly scorched.
Reverse to put back together.
Really easy job
Old Jun 24, 2005 | 06:02 PM
apples24's Avatar
apples24
cool confident now
Old Jun 24, 2005 | 06:10 PM
The DIVA's Avatar
The DIVA
Clutch change proper:
remove lower fairing
drop oil
remove r/h side engine casing
remove the 6 bolts from clutch cover and take off to expose plates
carefully remove plates one at a time noting sequence they come out
check steel plates for blueing and high spots
soak new fibre clutch plates in oil for half hour
rebuild clutch as it came apart with new fibre plates and replace cover
Carefully tighten/torque cover bolts(9-11lb ft)
replace engine casing
refill with oil,run up and check for leaks and correct clutch operation
replace lower fairing....
Easy huh.....
Replace clutch..Endurance method:
Drag rider off bike and chuck him in corner of pit garage
rip lowers off and dump bike on its side
buzz engine case of with airgun as quick as poss
while keeping now snarling rider at bay,tear clutch out and replace
throw thing back together and unleash psycho on to track again
Seek treatment for 3rd degree burns to fingers.......
Old Jun 24, 2005 | 06:14 PM
apples24's Avatar
apples24
ahh see there was me thinking the clutch engine cover was on left hand side
drop engine oil? box and engine not seperate?
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Lol at the endurance race maethod of changing clutch
Old Jun 24, 2005 | 06:15 PM
The DIVA's Avatar
The DIVA
motor and box is combined mate....
apples24's Avatar
apples24
see told ya i know fook all bout bikes lol
Old Jun 24, 2005 | 06:17 PM
apples24's Avatar
apples24
wot bout manifold ceramic gaskets couldnt find em to buy on net they main dealer only? they look simple enough to change
carl_harker's Avatar
carl_harker
if you lean the bike over you won`t need to drop oil. Also look for grooves in the clutch basket weak point.
Old Jun 24, 2005 | 07:46 PM
apples24's Avatar
apples24
according to manual theres fook loads to remove? thrust push rod, cerclips, opressure plate, hub nut, diaphram springs etc
loads more to remove than whats stated above?
Old Jun 24, 2005 | 08:02 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
I'd take NightDavva's word for it.....hes got hands like oven gloves so I'd believe every word he says! LOL!
Old Jun 29, 2005 | 08:24 PM
apples24's Avatar
apples24
hmmn according to the manual thers a friction plate with a larger internal diameter that gos in first etc then a plate then another friction plate etc etc but for the 600x model (mine) it says theres a friction plate that gos last that on original clutches has a green dot but i have a ebc aftermarket clutch, how will i know which is the one?
BlakeMoyle
Sep 1, 2015 02:24 PM
james kiely
Aug 28, 2015 08:58 PM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
