Mondeo steering rack help! - Pic included!
Old Jun 24, 2005 | 12:03 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Default Mondeo steering rack help! - Pic included!
Trying to replace the rod bit that the track control arm winds on to on my mk2 mondeo. This rod bit then bolts into the main steering rack. I've got the boot off and have it on full lock so that arm is as much towards me as possible.
But I cannot crack off the rod from the steering rack. Theres no nut on it and it is soo tight that I cant get it to budge with mole grips or a hammer and chisel.
Any suggestions?
Also does anyone know if you can replace the bottom ball joint (rubber boot split) rather than the whole wishbone?
Old Jun 24, 2005 | 02:17 PM
EssexBoyRacer
bttt really need some advice on this!
Old Jun 24, 2005 | 02:46 PM
EssexBoyRacer
Here's a pic to help give you an idea of what it is.
Old Jun 24, 2005 | 02:50 PM
ian sibbert's Avatar
ian sibbert
You need a really good pair of grips or stilsons mate...
They are threadlocked in..
You need to threadlock the new one back in too...
They are drumsticks IIRC..
Regards
Ian
Old Jun 24, 2005 | 02:59 PM
EssexBoyRacer
I'll have to do some tools shopping then. My mole grips just werent grippy enough. I cant believe they dont put any kind of nut on these!
Old Jun 24, 2005 | 03:01 PM
ian sibbert
Some have 2 flats to let you get a spanner on...some dont
Best of luck mate..
Old Jun 24, 2005 | 03:06 PM
EssexBoyRacer
these are completely round.
Cheers fella, Thank got I dont have to change the whole steering rack. Subframe off job!
Old Jun 24, 2005 | 04:31 PM
The Youth.'s Avatar
The Youth.
The rack comes out the passengers side without dropping the subframe
also it is much easier to remove and replace the bottom arm than try and press a new bush in, arms only cost 20 quid and take 20 mins a side to change once the wheels off. only need to undo 3 bolts!!
on the gearbox side you will need to hacksaw the head off the old bolt on the front mounting then invert a new bolt (cut it 3 mm shorter first to avoid it hitting the G box, when fitted tap over the top of the new bolt to stop it fro falling off as a sort of safety measure.
( I own 5 mondys so know a bit about them!!)
steve
Old Jun 24, 2005 | 05:00 PM
Danny boy's Avatar
Danny boy
job for nag me thinks lol
JoeyBoyden
Jan 4, 2024 02:36 PM
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
YODI
Aug 30, 2015 01:12 PM
borboyous
Aug 22, 2015 11:17 AM
