clicking noise (escort cosworth)
Old Jun 23, 2005 | 07:01 AM
rstoughy's Avatar
rstoughy
Default clicking noise (escort cosworth)
Hellp!!
My car has developed a clicking noise coming from the N/S front wheel area. The car has a slight wobble through the steering at around 65mph but gets worse when going round bends on the dual carrigeway, usually right hand ones.
Could this be a sign of a wheel bearing being on its way out or a fooked CV joint?
To start with i just put it down to the front wheels needing balanced but then i was driving down a narrow road with high walls on either side and i heard this clicking noise
Anyone else had the same with there Escort Cosworth or 4x4 Saff?
Your hellp is appretiated as always
Thanks
Paul.
Old Jun 23, 2005 | 07:18 AM
The Gravedigger's Avatar
The Gravedigger
Sounds just like what I just had: failed wheel bearing. Steering wobbling round corners, worse under braking, plus all sorts of odd noises. Turned out it was busy welding itself to the hub, so that needed replacing as well
Old Jun 23, 2005 | 08:42 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I had this happen at the Nurburgring (luckily just on the last few corners ). Turned out to be the wheel nuts had worked loose .
Old Jun 23, 2005 | 08:54 AM
rstoughy's Avatar
rstoughy
Deffo gets worse under braking!!
Will check all the wheel nuts tonight and if that dosent cure it then i will have to look at the bearings.
dont fancy having to replace the hub this early on into ownership
Old Jun 23, 2005 | 08:59 AM
Mike Rainbird
Caraholic
Also check that the hub nut that holds the bearing in place hasn't come lose, as this will cause the same symptoms...
Old Jun 23, 2005 | 09:03 AM
rstoughy's Avatar
rstoughy
Mike Rainbird,
will do
Old Jun 23, 2005 | 09:06 AM
The DIVA's Avatar
The DIVA
Come on fella.......it is a cossie you know...
You know your just dying to get the tools out,shouldn`t take more than an hour.
Old Jun 23, 2005 | 09:12 AM
rstoughy's Avatar
rstoughy
nightdavva,
Its not me M8, If the wife sees me ripping a car that i bought not a week ago apart ohhh i'll be for it
Might have to put it down as routine maintanence
Old Jun 23, 2005 | 09:36 AM
The DIVA's Avatar
The DIVA
Tell her now that you`ve got a goodun you want to make sure it stays that way,stick it on stands and take all four wheels off for effect...
Old Jun 23, 2005 | 09:42 AM
Damo V's Avatar
Damo V
Std brakes??
Old Jun 23, 2005 | 09:46 AM
Sticky.'s Avatar
Sticky.
Are you sure its not your wallet fell out under the passengers seat with all the money you have Paul
Old Jun 23, 2005 | 12:15 PM
rstoughy's Avatar
rstoughy
Damo V,
Yes M8 its got std brakes.
Sticker Paul,
I used to have money then 9yrs ago i bought my first cossie, Been skint ever since
more recently been coming on here and buying everything i see
Old Jun 23, 2005 | 12:30 PM
Sticky.'s Avatar
Sticky.
Well you no were to send the Racelines
Tryed calling yesterday, you off shore at the moment?
Old Jun 23, 2005 | 12:44 PM
rstoughy's Avatar
rstoughy
Sticker Paul
No,
Onshore hopefully for good now Only in emergencies will i go offshore. Much better being at home every night and weekend, means i can plan things like going down to Nat Day or going out for a beer at the weekends never been able to do that before
will send you a PM with my number, though im still nae sure if im wanting to sell
Old Jun 23, 2005 | 10:35 PM
rstoughy's Avatar
rstoughy
Wheel nuts all tight
Driveshaft nut is tight as well (16+stone on my 24" breaker bar and it didnt move)
Clicking noise is still there Guesing its the wheel bearing so might have to pull it apart this weekend and stick a couple of new ones in. (routine maintenance)
Put my stereo in tonight as well so at least i wont hear the clicking driving to work tomorrow
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
