Two annoying electrical problems
Old Jun 21, 2005 | 01:41 PM
Paul Eggleton's Avatar
Paul Eggleton
Default Two annoying electrical problems
1) when I use the front squirters on windscreen the rear one squirts too . Surely this isn't how it was designed. I can easily unplug the pump to the rear but I wouldn't mind a proper fix.
2) Sometimes(its becoming moore often) when i press the boot release button inside I hear the solenoid move but it doesn't release fully. The light for the rear heated screen comes on the Dash too
On the second one, is it usually the wiring on the joint of the hatch thats got squashed and worn over time. Has anyone ever replace any off it.
Old Jun 21, 2005 | 01:43 PM
Neil S's Avatar
Neil S
Isnt there some kind of escos stalk problem? I'm sure I remember reading something about that before
Neil.
Old Jun 21, 2005 | 05:04 PM
Dave Henshall's Avatar
Dave Henshall
if both jets are squirting it the pump thats fooked, it has 2 nrv insode , the pump runs one way and blocks one port off, when th epolarity is reversed, it runs the other way and block the opposite port off,
could cure it my pulling it out (under the passenger arch liner at the front) and run some water through it as it may just be a bit of crap that is stuck inside it.
Old Jun 21, 2005 | 05:05 PM
Dave Henshall
the tailgate, sounds like a bad earth if its lightingup the HRW button... try ajusting the bump stops for the tailgate see if they are set higher, it pops open when u press it...
Old Jun 21, 2005 | 06:02 PM
Paul Eggleton
Top man Dave, I'll check this out. I'm sure I saw two pumps on the washer bottle though. will see later
Old Jun 21, 2005 | 06:09 PM
pee vee's Avatar
pee vee
there are 2 pumps on the washer bottle
one for screens, other for the headlamp washers paul
the headlamp washers are more high pressure. so its a seperate pump for that
(pretty sure )
Old Jun 21, 2005 | 06:18 PM
Dave Henshall
correct, you dont need any tools or to undo anyting to get the screen wash pump out either just some elbow grease...
Kam B
Sep 24, 2015 10:40 AM
Fudgey
Sep 17, 2015 01:06 PM
tib2220
Sep 14, 2015 12:33 PM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
