injectors
Old Jun 18, 2005 | 10:22 AM
AdamB's Avatar
AdamB
Default injectors
i'm needing 4 x injectors of at least 280cc
what colours can i look for and are all injectors the same fitment?
to be fitted to some jenvey t/b's and a mondeo/focus loom
Old Jun 18, 2005 | 11:17 AM
tonyturbo's Avatar
tonyturbo
low impedence or high impedence?
Old Jun 18, 2005 | 01:05 PM
AdamB's Avatar
AdamB
erm...
what does what? all i've been told is that i'm gonna need higher flow injectors
and have been given a simple equation of divide the flow rate in CC by 5, then multiply by the number of injectors you plan to use
am fitting a 2.0 blacktop zetec into a mk4 fiesta and running it on jenvey 45's (possibly 48's) and omex management
wanting about 250bhp, so my conclusion is 300cc injectors (300/5 = 60... x 4 = 240)
Old Jun 18, 2005 | 05:25 PM
AdamB's Avatar
AdamB
can someone please help? as far as i was aware before tday that injectors were pretty much all the same, just the flow rates differentiated
Old Jun 18, 2005 | 08:10 PM
xr2itrojan's Avatar
xr2itrojan
if you are going to be running omex i dont think it matters about the impedance but to fit a zetec fuel rail u will need side feed injectors. unless you fabricate 1 of your own to use end feed injectors like the frst which has a wider variety of performance injectors. hth
Old Jun 18, 2005 | 08:12 PM
xr2itrojan's Avatar
xr2itrojan
ring whoever it is that is going to be mapping ur omex for u and ask them what injectors they think u should use
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
