Boost controllers
Old Jun 12, 2005 | 02:02 PM
Fiecos Dan's Avatar
Fiecos Dan
Default Boost controllers
i'm lookin for a stand alone boost controller. for my cossie.
i want a contoller i can press in a set boost level, (say 30 psi) and for the boost to be 30psi from 4k rpm in 1st gear, to 7.7k rpm in top gear.
wots good?
Old Jun 12, 2005 | 02:14 PM
GARETH T's Avatar
GARETH T
i dont like boost controllers myself,,, i believe that they are taking away one major factor of engine control away from the ecu?
would you run a seperate ingition controller?
Old Jun 12, 2005 | 02:17 PM
GT2's Avatar
GT2
Turbosmart e-boost.
Old Jun 12, 2005 | 02:20 PM
Fiecos Dan's Avatar
Fiecos Dan
not really as at mo i'm only usin a actuater to controll boost, the only problem is it runs more boost in higher gears.(due to more load).
the map sensor controlls fuelin to boost, so runnin a boost controller, as long as the ecu's mapped to run sed boost, will not have a problem.
but if the controller fails, its very much like if a airinj fails, or actuater pipe fails.
Old Jun 12, 2005 | 02:31 PM
Ish's Avatar
Ish
the apexi avc-r is very good althought it can be tricky to set up.
it allows you to set boost by rpm, gear etc. has loads of other features as well.
see here for more info http://www.apexi-usa.com/product_ele...=200&pageNum=1
Old Jun 12, 2005 | 09:15 PM
Fiecos Dan's Avatar
Fiecos Dan
who sells the apexi stuff in the uk?
Old Jun 12, 2005 | 09:27 PM
Ish's Avatar
Ish
loads of places. just look in the back of one of the jap magazines or ask steve n as he will probably know who does the best price in the uk!
Old Jun 12, 2005 | 11:36 PM
Ginge !'s Avatar
Ginge !
just finding my feet
the thing about aprxi is its designed to run on a jap ecu as they have outputs for it
speak to RSNISSAN as hes a genuis with apexi's as he had one in his old gtir and hes fitted a few for others too
Old Jun 13, 2005 | 07:15 AM
GARETH T's Avatar
GARETH T
i agree with you,,,, but when the ecu wants to run slightly less boost,, it cant
Old Jun 13, 2005 | 07:36 AM
Joris_FRST's Avatar
Joris_FRST
can't you use the amal valve output to an input on a the apexi (if it has some "extra" inputs)
Old Jun 13, 2005 | 08:51 AM
rs cos's Avatar
rs cos
turbo smart e-boost! adjustable sensitivity, gate control , 3 boost set points which you can set, overboost setting , peak boost recall etc
Old Jun 13, 2005 | 08:55 AM
St3V3_C's Avatar
St3V3_C
An interesting and informative discussion on boost control here:
https://passionford.com/forum/viewtopic.php?t=66819
HTH
Old Jun 13, 2005 | 09:42 AM
Default Re: Boost controllers
wots good?
That may not actually be possible at all, ie the rate the car accelerates in 1st might mean the turbo cant physcially spool up quick enough to keep with the demands you are making of it.
But TBH for what you want, just use an MBC, for just one set value they are great and they eliminate wastegate creep more or less totally, which will make a massive difference to 1st gear boost.
Old Jun 13, 2005 | 12:47 PM
nthorpey's Avatar
nthorpey
i use an a'pexi avc-r and find it excellent, need to read the manual and it all becomes clear. Will work with ANY ecu as it ONLY controls boost. to have gear selective boost you will need a compatible speed sensor, normally from a jap car ? i am going to use a custom one which also drive the stack speedo
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
