Replacing the front brake lines ??? On 2wd cossie
Old Jun 12, 2005 | 01:51 PM
Alan s1's Avatar
Alan s1
Default Replacing the front brake lines ??? On 2wd cossie
Ok im going to replace the front break lines with braided ones BUT do i do away with the old copper lines that come up of the calliper to the shock
And replace them completly in one line or do i do it in 2 lines Eg as they are now but both in braided
I have done the rear ones where they run along the rear arm in copper And have replaced them with braided and look the Nuts
Old Jun 12, 2005 | 08:28 PM
Alan s1's Avatar
Alan s1
Ok to make it simple do i use 2 hose or just have 1 going from caliper to the body
As you can see i replaced the 3 parts on the rear with just the 2 bits
Old Jun 12, 2005 | 11:23 PM
Alan s1's Avatar
Alan s1
Anyone May just make 2 hose up simaler to the one old design Eg just relace the copper one with Braided hose and then from the shock to the calliper
Old Jun 13, 2005 | 07:06 AM
SteveB's Avatar
SteveB
I always use a 4x4 kit and loose the copper pipe
Old Jun 13, 2005 | 03:23 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Alan, what steve says is what we did on MrsFrog's.
PS: I thought you had made a hole in your boot with that rear beam picture, it kind of looks like your boot floor has been cut away at first
Old Jun 13, 2005 | 03:59 PM
R4N SS's Avatar
R4N SS
no idea but when you're done u can do mine
Old Jun 13, 2005 | 06:30 PM
aRSe's Avatar
aRSe
I've always viewed flexi lines as a necessary evil, as when the line moves, due to the wheel turning or the line expanding under pressure, its internal volume will alter, leading to a less precise feel at the pedal. How much of a difference it makes in practice, i can't say, as i havn't done back to back tests, but the theory stands up.
Did 'tiny' give you that blue paint?
Old Jun 14, 2005 | 03:13 AM
Alan s1's Avatar
Alan s1
Steve@SCC, Well its now got new copper pipes both sides same as the standard ones were Due to it snapping when i canged the disks and pads And i could not get any where to get the parts to make the Braided ones up as the cossie was in bits
But i will do away with them when i get the draided ones done
Greg no m8 no cutting BUT Very fooking Thight to get it in
Ran sod off my cossie is still sat on my m8s ramp due to not being able to undo the rear Hub Nuts 1's off (2hours later that is) And im going to take the othere one in the arm over the road and get the GAS on it
aRSe, Fook it if it works for the time i own it it will do And No to the paint But you could have said it cost me loads in bloody hamerite
Couple of picks
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Aug 10, 2015 12:08 PM
Red_bull
Aug 9, 2015 08:34 AM
Bosch
Aug 4, 2015 05:14 PM
