pinto ignition problem.....
Old Jun 12, 2005 | 12:51 PM
Ade's Avatar
Ade
Fast Ford snapper
Default pinto ignition problem.....
Just started last night.....
Car seems ok up until over 100MPH in 5th when it starts spluttering and dying, (I was later told that yellow flames were coming out the exhaust when this was happening!).
Its ok if I back off a bit, I'm guessing some part of the ignition system isn't working right when its needing a good spark on heavy load, and the fuel's just igniting in the exhaust...
I replaced the dizzy cap and rotor arm just there with no change in syptoms.
Its a 2.0 pinto with a Lumenition kit.......
Any ideas people?!
Old Jun 13, 2005 | 05:52 PM
Ade's Avatar
Ade
Fast Ford snapper
Didn't have time to do any work under the bonnet today as I was driving everywhere......
but...
Whist caning it up a long hill I tried pulling the choke out when it started spluttering............. instantly stops spluttering!
(Still not as good as it should be, but not dying on its arse at least).
So, some kind of fuel shortage????
Any ideas much appreciated!
Old Jun 14, 2005 | 02:29 PM
Ade's Avatar
Ade
Fast Ford snapper
Old Jan 4, 2012 | 10:59 AM
clyde 1800's Avatar
clyde 1800
is it an injected pinto or carbed?
Old Jan 4, 2012 | 11:30 AM
Ade's Avatar
Ade
Fast Ford snapper
Whoop! Six and a half years later I got a reply!
I honestly cant remember what this problem ended up being, but I did run a Pinto in my Capri for a couple of years after this date!
Old Jan 4, 2012 | 11:59 AM
clyde 1800's Avatar
clyde 1800
ive probably met you before did you ever take pictures of a mark 1 escort camper with a bda in it?
i just searched pinto ignition problem to see if any1 had experienced what im having trouble with i posted it not to long ago with a video
take a look at my build thread you might find it interesting
Old Jan 5, 2012 | 12:02 PM
Ade's Avatar
Ade
Fast Ford snapper
Nope, wasn't me!
I'll have a nosey....
Old Mar 17, 2012 | 08:43 PM
clyde 1800's Avatar
clyde 1800
just sounded like to much fuel of bad earth to the ignition system or even possibly behind on timing slightly?\
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
beller
Sep 21, 2015 04:13 AM
steff19
Escort Range
Sep 9, 2015 10:14 PM
