Cossie owners - Some VERY good advice for ya !
Old Jun 12, 2005 | 12:30 PM
ECU Monitor Enthusiast
Default Cossie owners - Some VERY good advice for ya !
All you cossies owners...Some good advice !
***** CHECK YOUR CRANK PULLEY IS CORRECTLY FITTED AND TIGHTEND UP ****
Over the last few years, because of my pulley being loose, it has caused loss of performance and the destruction of my crankshaft.
Basically, the loose pulley has caused the wearing out of the woodruff key and the hole in the crank it goes into is soooo big now, the pulley is no longer a snug fit and is loose.
I have been told the woodruff key is only used to locate the pulley but no matter how tight the bolt is, over time the pulley moves.
The result is the pulley is no longer in the correct place and the result is retarded ignition (22 degrees) and loss of power.
This has been a gradual thing as the pulley over time has rotated on the crank shaft so was not noticable straightaway.
Initially this was not a problem as I reprogrammed an ignition offset in the ecu to compensate for this and the performance of the engine was restored.
Well the other day, was driving home and the cars starts miss firing very badly.
Luckily, I had my laptop with me and plugged it into the ECU to read out the problem.
Straight away, I found out it was a crank sensor fault, so I lifted the bonnet to have a look and all was ok.
By pure chance while under the car, I grabbed the pulley and to my surprise it was very loose.
So loose in fact, the pulley was moving away from the crank sensor so causing the missfire.
When I got the car home, I thought i just needed to tighten the pulley clamp bolt up.
When I tried to tighten it up I found it was already tight.
The pulley has worn so much (being only mild steel) it has worn out the internal hole and also the clamping surfaces too.
The result, the pulley is a write off.
Not finished yet .....
Anyway, I managed to obtain a brand new pulley and fitted this.
This was surely the answer to my problems......NOPE
The new pulley along with its factory powder coating was causing the drive belt to squeal. (new belt fitted)
Took the pulley off, and had it sand blasted to remove the coating and this problem was sorted.
Still not finished......
Drove the car again last week and the car felt flat again so I checked the pulley once more only to find it loose once more.
It turns out, the old pulley, although is made of mild steel has also worn the end of the crankshaft.
The woodruff key hole in the crank is now 12 mm wide (should be about 5mm).
The end of the crank shaft if now a tappered shape.. I.E it is smaller at the front by 2mm diameter
Well now my options are ...
1) Bodge it once more and wait for it to get worse.
2) Custom pulley made to fit - engine out - would need to remove old crank to get it balanced with new custom pulley.
3) Fit a new crank - engine out.
I have chosen the new crank route. May aswell as the engine has to come out for the best 2 options.
While its out, may aswell do some mods too
Fookin cars - yet again.
Old Jun 12, 2005 | 12:35 PM
pee vee's Avatar
pee vee
nightmare mate! sorry to hear,,
but!
guess you gotta keep the escort for a bit now then simon!
Old Jun 12, 2005 | 12:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Bad news mate
Old Jun 12, 2005 | 01:11 PM
DAN P's Avatar
DAN P
sorry to hear that si
Old Jun 12, 2005 | 01:21 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I've heard of this happening before.
he spent ages trying to sort it cos it was itermitant power loss (it only happened when he was driving it) turned out it was this problem too.
sorry to hear it. Hope you sort it quickly
Daniel
Old Jun 12, 2005 | 01:31 PM
dave cos4x4's Avatar
dave cos4x4
Bit of a mess then.
Caused a big problem for you Simon.
Dave.
Old Jun 12, 2005 | 02:03 PM
markk's Avatar
markk
i'll not worry about it too much , as mine has been lockwired since the day i built it , along with 90% of the rest of the cars bolts, unfortunatly the old YB has some serious NVH issues
Old Jun 12, 2005 | 02:08 PM
GARETH T's Avatar
GARETH T
been through it all myself simon
Old Jun 12, 2005 | 02:14 PM
Paul Eggleton's Avatar
Paul Eggleton
Simon, you could just get the end of the shaft rebuilt rather than get a whole new crank. They basically spray on metal and then turn it down to the right size. We do it a lot at work with worn roller shafts.
Old Jun 12, 2005 | 03:00 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
if you need a good crank then look at the one ive got ending on ebay tonite.
its standard standard grind,getting rare now.
Old Jun 12, 2005 | 03:16 PM
Turbo lag's Avatar
Turbo lag
My pulley wasn't loose it was welded to the crank, took ages to get it of with a big chisel and a FBH
Old Jun 12, 2005 | 03:21 PM
ImaRacing 700's Avatar
ImaRacing 700
My pulley just fell off when i undone the bolt!...Didnt cause any noticable issues though ...Put a brand spanking crank in now and boy what a tight fit Vicar
The only problem was forgeting to put the fooking grp a cambelt on before putting pulley on Trying to get the puley off was a total bitch
Old Jun 12, 2005 | 03:29 PM
john_p_b's Avatar
john_p_b
is this a wear issue or purely a case of incorrect refitting?
Old Jun 12, 2005 | 03:31 PM
ImaRacing 700
Wear...my og crank had done around 130000 miles!
Old Jun 12, 2005 | 03:59 PM
Chris Honeywell's Avatar
Chris Honeywell
Well i had a crank fall off on the m25 with the bolt still attached to the crank
only thing was the end of the crank had fell off
Bad luck Simon stick a new crank in
Old Jun 12, 2005 | 04:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Just been out and checked,mine is ok.
Old Jun 12, 2005 | 04:07 PM
Dave Henshall's Avatar
Dave Henshall
can you check just by grabbing hold of it, even with the polyV belt still on,,>?
Old Jun 12, 2005 | 06:40 PM
Damo V's Avatar
Damo V
Someone posted up an identical thread to this a while back..?? was it Gareth?
Old Jun 12, 2005 | 06:45 PM
GARETH T's Avatar
GARETH T
damo dont think ive posted about it before,,, but it is worth checking
you really gotta take the poly v off to feel it better
Old Jun 12, 2005 | 11:43 PM
Ginge !'s Avatar
Ginge !
just finding my feet
it was simon who posted it about a year ago
he dont seem to be having much luck with pullys
this will make ya laugh though, my engine bay totally covered in oil the crankl pully os on there solid
Old Jun 13, 2005 | 05:19 PM
b19bal,
Ginge, you are right, I did
Just goes to show how long this problem has been around
Got a new crank on the way
markk
Dec 2, 2021 06:59 PM
162
Dec 25, 2019 09:43 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
knight19770
Aug 4, 2015 12:36 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
