4x4 Diff pinion seal leak..again
Old Jun 7, 2005 | 10:40 AM
Dean Saff's Avatar
Dean Saff
Default 4x4 Diff pinion seal leak..again
Ive changed my rear diff pinion seal as was leaking and within a 100 miles it's leaking again all over my restored underside
Could this be caused by worn diff bearings?...
Also does the 2wd diff fit a 4x4? Ive heard a few people mention this..
If so what are the advantages?..
Cheers Dean.
Old Jun 7, 2005 | 10:41 AM
Azrael's Avatar
Azrael
Default Re: 4x4 Diff pinion seal leak..again
You need 2WD rear beam. It's heavier but stronger.
Old Jun 7, 2005 | 04:52 PM
2001ode's Avatar
2001ode
Hi
3 reasons for oil leak on rear axle :
as you say : worn diff bearing
too much oil (normaly, 5mm below plug)
default on vent of case rear axle : check if not blocked
Regards.
Old Jun 9, 2005 | 01:40 PM
Dean Saff's Avatar
Dean Saff
Originally Posted by 2001ode
Hi
Regards.
Cheers mate vent is clear may have a little too much oil,
I'm hoping that will be the problem.
I'll scrap the 2wd diff idea as my beam etc has just been restored.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
muzzman1
Sep 30, 2015 08:59 PM
