anyone running diamond cut rs 7 spokes
When I fitted mine the normal bolts worked fine, its just that you will also need collets to go with them, my RS7's where from Fordparts UK who supplied the collets with the wheels. If your struggling then give them a try.
Mark
Mark
you should get nuts with the alloys if so cut the collets off just done mine i found it easy to just file the edge down and the collet should drop off, i think you need some new bolts to compensate for the length of the collet is that right???
where will i get longer bolts from then?
do ford do them
I'm currently running diamond cut 7 spokes on my Series 2 with no clearance problems due to using standard ride height springs. I bought these wheels new from my local Ford dealership some time last year and they did'nt come supplied with bolts long enough ! The bolts, as mentioned in the post above, need to be longer to compensate for the collet. I was able to purchase these from my local wheel refurbisher. They are a company called SEM and they are located in Sunderland, Tyne & Wear. You can contact them on 0191 548 0617.
Hope this helps,
Regards,
David.
Hope this helps,
Regards,
David.
I run these wheels, have done for about a year almost? As said, I cut the collects off with the grinder and I used the original bolts no problem.
I plan to eventually change to a stud and nut conversion anyway
cheers for replys
i remember someone sayin that the normal bolts will work but it needs to screw in a certain percentage of the bolts length or you risk the wheel fallin off
coz of no search button i cant find it
the collets are definitely the right ones as they are made for rs 7 spokes so cut them off, the length of the bolts is my problem i got some new bolts from "3drstretch" pm him im sure hell sort you out, but if adam has used the original bolts from the standard alloys? then that should do
So much easier and safer too!!!!
Vacuman
16
Sep 3, 2015 06:26 AM
