Need some car audio advice !!!
Old May 25, 2005 | 07:20 PM
glenrs2k's Avatar
glenrs2k
Default Need some car audio advice !!!
hello all, ive been installing some car audio and now i have it fired up it sounds ok but if i turn the volume down there is a humming noise, anyone know what may cause this and what i can do to cure it cheers
Old May 25, 2005 | 07:31 PM
georgie1's Avatar
georgie1
hi m8, if you have run your rca leads too near the power lines to the amps you will pick up interferance from the engine. you need a noise resistor (i think thats what its called) that will stop the interferance, you can get them from any car audio shop or somewhere like halfords tell them what its for and they will give you the right thing.
Old May 25, 2005 | 07:35 PM
GARETH T's Avatar
GARETH T
sounds like a cheap amp too me,,,, supression is crap in them
it is good practice to run the rca's away from the power cables,, but in practice (done a far few) it doesnt make a blind bit of difference
Old May 25, 2005 | 07:56 PM
glenrs2k's Avatar
glenrs2k
Its a directed Audio amp so it pretty good quality i have run the pwer cable and rca leads seperate but have run the amp remote with the rca lead
j.hammond1
30
Oct 31, 2021 05:28 PM
c14rks
Aug 11, 2015 05:17 PM
knight19770
Aug 4, 2015 12:36 PM
