ecu differences?
Old May 25, 2005 | 10:45 AM
mart.rs's Avatar
mart.rs
Default ecu differences?
I have an f-reg s2 with an ecu that has a blue,red and black square on it.
i have purchased a chipped ecu with a heart and triangle and a dash on it that i think is from a g-reg car am i able to fit it? if not then i will sell it!
Old May 25, 2005 | 10:56 AM
rsjohn's Avatar
rsjohn
Yes will fit fine mate
john
Old May 25, 2005 | 11:07 AM
mart.rs's Avatar
mart.rs
ive been told that there is a difference between a 90 spec and an 88 spec,im very confused! ive also been told that if i drive mine to get it set up with it on which is booked at engine advantages in two mths,that it will fry it because of a knock sensor or not?
Old May 25, 2005 | 11:23 AM
kay2's Avatar
kay2
I was under the impression it would cause running problems?
thought u needed the right ecu for the year ie post or pre 90
Old May 25, 2005 | 11:28 AM
Alvyn's Avatar
Alvyn
If you are stuck I have a chipped blue/red/black ecu £110 posted
Old May 25, 2005 | 11:53 AM
mart.rs's Avatar
mart.rs
well the only problem i have is im now stuck with an ecu that i dont need? would like to avoid paying out for another unless i can do some sort of tradekay2, ,
Old May 25, 2005 | 11:56 AM
mart.rs's Avatar
mart.rs
intrested yes but do you know what chip it has in it sorry but just want to make sure it able to go over 15psi if i need to
Old May 25, 2005 | 12:03 PM
kay2's Avatar
kay2
not interested in a trade mate, im converting mine to efi so just gettin rid of all the parts i dont need from the efi cheap
Old May 25, 2005 | 12:04 PM
Alvyn's Avatar
Alvyn
chip was boosting to 22psi and 220bhp the chips from a company called Detection Techiques ltd in Buckinghamshire
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
liamT74
Sep 23, 2015 10:24 PM
