Picked this up tonight (Pic)
Might not mean much to you guys, differn't kettle of fish to the sort of things you nutters do, but it should keep me occupied throughout the summer.
I know a few of you will know what it is at first glance (Chip, Rob (his engine) Nickyboy etc etc)
Its a vauxhall C20XE, but i decided to supercharge it, just to be differn't. Its been done a few times before (http://www.tsr.nu/) on a red mk3 gsi, I'm aiming for the same sort of thing, but a few differneces like location of the TB, its going to be *Intake > AFM > Charger > Intercooler > throttle body > Inlet*
What i'll do, is get a build up of pics then post in the restoration/rebuild forum otherwise it'll be like 2 pics a month as its quite a big project for me with regard to drawing up plans for custom inlet, brackets, relocation alternator etc etc & also fitting low comp pistons, having headwork done, block blasted, refaced & honed, crank is also going to be sorted out.
So yeah, well pleased
That must be the 3rd XE thats been in the boot of my astra, but this time its mine
I look forward to seeing it once its got the charger on it mate, nice idea for a conversion.
Let me know if you need any help with regards to the fuelling etc.
Also, got a shopping list....LET pistons are on the agenda or anything low comp. i would ask Rich, but he doesn't break LET's does he? just sells them whole
P.s Cheers nuts
EDIT: Chip..lol just remembered. Fueling, hmmm, i sortof hit a grey area with that. The standard fuel rail intake & return hoses will foul the custom manifold, and will also be resting ontop of the charger, which i don't want
Basically what i need is a fuel rail with the inlet & return points on the ends of the rail, and an aftermarket FPR.
Hmmm, went a bit quicker than i expected
Just can't get that damn crank pulley bolt off
anyway, here's some pics of the engine in my workshop/bedroom:
Head underside:
Coscast
(Me & Rob didn't know till i stripped it down. A nice bonus for me)
Block in the boot:
A bit of water ingress:
Cams & tappets:
Cam retainers & con rods:
crank retainer thingies and conrod shell thingies:
The block:
And another:
Head underside:
Coscast
Block in the boot:
Cams & tappets:
The block:
And another:
A small update:
Someone thought they would try their hand at head work
incompetant wankers.
A nice dink where the lifter goes
Cleaned and checked valves
all stil straight (u'll see why i was concearned in a minute)
All four were like this, i was lucky the valves wern't out of shape
Getting ready to do some bowl work
Inlet
Nice and clean
Thats it for now
P.s, can i have this moved to restoration forum please? ta
Inlet
Nice and clean
Thats it for now
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
STAFFY OWNER
Sep 13, 2015 08:59 PM
